Proof of Congruence Transformation
  • Context: Graduate
  • Thread starter Thread starter azizz
    Proof Transformation
The discussion revolves around the properties of positive semidefinite matrices and the implications of transformations involving a complex matrix T. Participants explore the conditions under which the statement "if T*AT >= 0, then A >= 0" holds true, particularly focusing on the rank of matrix T and its implications for the positive semidefiniteness of matrix A.
  • One participant questions whether the converse of a known result about positive semidefinite matrices is true, specifically if T*AT >= 0 implies A >= 0.
  • Another participant argues that the converse is not generally true, providing an example where T is a column vector and explaining that T*AT >= 0 does not guarantee A is positive semidefinite.
  • A sufficient condition for the converse to hold is proposed: T must be surjective, meaning it has full row rank.
  • Further clarification is provided that A >= 0 implies T*AT >= 0 if T has full column rank, but this does not hold if T lacks full column rank due to linear dependencies.
  • Participants discuss the necessity of T being surjective for the converse to hold, leaving the question open for further consideration.
Participants express differing views on the conditions under which T*AT >= 0 implies A >= 0. While there is agreement on the sufficiency of T being surjective, the necessity of this condition remains unresolved.
Participants note that the implications of the transformations depend on the rank of matrix T and the definitions of positive semidefiniteness. The discussion highlights the complexity of the relationships between the matrices involved.
azizz
Consider the following statement
Let T (size: nxm) be a complex matrix. Then if A of dimension nxn is positive semidefinite then T*AT >= 0.
Now I was wondering if the converse is true aswel? In my math book they used the converse statement to proof something, but is it possible to say that if T*AT >= 0 (positive semidefinite) then A>= 0?
Note: I used the symbol * to indicate the Hermittian.
Someone got some tips for me?
It's not true in general. Suppose, for example, that T is n x 1. So it's a particular column vector; let's call it [tex]x_0[/tex] to emphasize that fact.
Then in that case, T*AT >= 0 means simply that
[tex]x_0^* A x_0 \geq 0[/tex] (scalar inequality)
for that specific [tex]x_0[/tex] (or any scalar multiple of [tex]x_0[/tex]). But in order to conclude that A is positive semidefinite, you would need
[tex]x^* A x \geq 0[/tex]
for EVERY column vector x.
[edit]: A sufficient condition for the conclusion you desire would be that T must be surjective. Do you see why?
Thanks for the fast replay. Let me see if i got.
A>=0 implies T*AT>=0 if T has full column rank. That means that for every column (i) of T we have Ti*ATi>=0.
If T did not have full column rank then there are linear dependent columns for which it does not hold that Ti*ATi>=0.
No, that's not right. A >= 0 implies T*AT >= 0 for ANY complex n x m matrix T.
Why is this? Because
x*(T*AT)x = (Tx)*A(Tx) = y*Ay >= 0 because A is positive semidefinite
(here I have defined y = Tx for added clarity)
You asked about the converse: when does T*AT >= 0 imply A >= 0?
A sufficient condition is for T to be surjective, i.e., for T to have full ROW rank. (Not full column rank! The n x 1 example I gave in the last post has full column rank, but the desired result does not hold.)
Why is it sufficient for T to be surjective? Let y be any n x 1 vector. We want
y*Ay >= 0.
Since T is surjective, there exists a (m x 1) vector x such that y = Tx.
Then:
y*Ay = (Tx)*A(Tx) = x*(T*AT)x* >= 0 because T*AT is positive semidefinite. QED.
The next natural question is: is it also NECESSARY for T to be surjective? I'll let you think about that one.
  • · Replies 0 ·
