Quantum mechanics replacing bohr model
The discussion revolves around the behavior of electrons in atoms, particularly in relation to energy levels, photon emission, and the implications for chemical stability. Participants explore concepts related to quantum mechanics, atomic interactions, and thermal energy generation through friction.
  • Some participants inquire whether all electrons in an atom must change energy levels to emit light, or if only valence electrons are involved.
  • One participant suggests that when an electron changes its energy state, a photon is emitted, but questions remain about the number of photons and their wavelengths.
  • Concerns are raised about the stability of atoms when electrons are excited to higher energy levels, with examples provided regarding helium and chemical properties.
  • Another participant discusses the implications of electron excitation on molecular stability, referencing processes like photodissociation and the effects of UV light on DNA.
  • Questions arise about the generation of heat through friction, with participants discussing the role of kinetic energy and whether it leads to electron excitation.
  • Some participants clarify that heat generation from rubbing objects is due to kinetic energy transforming into thermal energy, rather than direct electron interactions emitting radiation.
  • There is mention of thermal radiation and how it relates to temperature, with a distinction made between electronic excitations and thermal energy at normal temperatures.
Participants express varying views on the relationship between electron energy levels and chemical stability, as well as the mechanisms behind heat generation through friction. The discussion remains unresolved regarding the specifics of photon emission and the conditions under which electrons can be excited.
Participants highlight the distinction between electronic excitations and thermal energy, noting that heat can cause electronic excitations only at very high temperatures. There is also ambiguity regarding the stability of atoms and molecules when electrons are excited.
kashiark
do all of the electrons in an atom have to move up or down an energy level or is it just the valence electrons or what? is there one photon released per electron and are they all the same wavelength?
You are trying to ask something like. "I heard an explanation on how atoms emit light. I understand it has to to with electrons jumping from one energy state into another. I am confused as to which atoms participate in this process, and how many photons are emitted."
I'll answer anyways: It doesn't matter which electron changes its energy state, when it does one photon is released carrying away the energetic difference.
but if only one electron did this and changed energy levels wouldn't it change the chemical properties of the atom? for instance, if one electron in helium moved up an energy level it wouldn't be stable anymore and it would have different chemical properties
It would have different chemical properties, yes. I'm not sure what you mean by 'stable' - atoms are quite stable. But if you excite (move up in energy) an electron with enough energy (the ionization potential), it may leave the atom altogether.
If you're referring to molecules, then yes - exciting an electron can destabilize it, causing it to fall apart (photodissociation). Or form a bond. Most molecules are, in most cases, stable. But for example: if UV light hits an electron in the double-bond in a thymine base-pair in your DNA, it'll temporarily break that bond - at which point the thymine might react by forming a bond to a neighboring thymine instead - causing what's called a 'thymine photodimer'. Which in turn distorts the shape of the DNA double-helix, which means the DNA of that cell stops working correctly, and if you're real unlucky, you get a melanoma. (now that summer is on its way, a skin-cancer warning would be appropriate - wear sunblock all you pasty white physics geeks! :D)
But at ordinary temperatures, electrons don't stay in excited states for very long. (how long does your average object glow after you turn out the lights?) So you don't usually talk about chemical properties of excited molecules - since they can't be kept around and chemically isolated and so on. Rather you just talk in terms of which photoreactions, if any, can take place.
ah i see ok ty and i meant chemically stable but i have another question; if you rub two objects together underwater they can keep putting out heat energy forever; once all of the electrons are in their lowest level wouldn't the heat energy stop being put out? or does the kinetic energy from moving the objects cause some of the electrons to move up an energy level?
When you rub two objects together and generate heat from the friction, the energy comes from you, and is transformed into vibrational/heat energy in the object. You can't cool an object by rubbing it. Is this what you meant?
oooh ok i get it now i was thinking that when you rubbed two things together their electrons interacted and emitted infrared radiation but i take it that they interact without dropping energy levels by emitting virtual photons and cause the opposite object's atoms to move erratically or move however solids do when they're hot
Here's what happens when you rub two objects together:
1. You add kinetic energy to the object by rubbing the objects together, striking them together, etc. The atoms in the object gain kinetic energy. Soon enough this internal kinetic energy reaches thermal equilibrium. If you dropped the object on the ground, you might have vibrations of a certain frequency and a large amplitude ringing throughout the object, especially if it's metal and the ground is hard, but eventually that one frequency component with a big amplitude becomes a distribution of frequency components with small amplitudes. This is thermal energy.
2. All objects emit thermal radiation, which consists of light in a distribution of many different frequencies. The higher the temperature, the higher the frequency that's being emitted the most. At room temperature, the peak amplitude is in the infrared, but if we heat something up enough, it'll be glowing hot, and the peak amplitude will be in the visual frequencies.
This is not to say the electrons from different surfaces don't interact with each other and emit stuff. I mean, if you can peel Scotch tape in a vacuum and create x-rays, then it seems anything's possible. Nevertheless, you don't need to consider the surface interactions to explain why rubbing objects produces heat.
No, not with normal temperatures. The states that normally correspond to heat is the kinetic energy of the atoms/molecules (their translational speed), their rotational energy levels, and their vibrational energy levels. (they have discrete levels just like the energy levels of the electrons).
Heat can cause electronic excitations, but only at very high temperatures.
ooh ok i get it thanks guys!
  • · Replies 23 ·
  • · Replies 36 ·
10K
