Length Contraction/Time Dilation
  • Thread starter Thread starter prime-factor
    Dilation Length
The problem involves calculating the speed required for a spacecraft to travel to Alpha Centauri, which is 4.0 light years away, in a time frame of 3.0 years as experienced by the travelers on the spacecraft. The discussion centers around concepts of length contraction and time dilation in the context of special relativity.
  • Mixed
  • Participants explore the relationship between distance, time, and speed from different reference frames, questioning how to apply the formulas for length contraction and time dilation together.
Several participants have attempted to set up equations based on the perspectives of both the spacecraft and Earth. Some have provided explanations and alternative approaches to clarify the concepts, while others express confusion about the application of the principles involved.
Participants are navigating the complexities of special relativity, including the implications of time dilation and length contraction, and are discussing the need for clarity on how these concepts interact in the problem context.
prime-factor
The Star Alpha Centauri is 4.0 light years away. At what constant speed must a spacecraft travel from Earth if it is to reach the star in 3.0 years, as measured by the travelers on the spacecraft .
Length Contraction:
L = Lo*(sqrt(1-(u2/c2))) , Lo = Length proper
Time Dilation:
T = To / (sqrt(1-(u2/c2))) ,To = Time proper
Because I'm new to the topic I can only use the formulas for basic length contractions and time dilation. But I am unsure how to use them together. Any help + explanation will be greatly appreciated.
Well, you know that, in the spacecraft 's reference frame, it takes 3 years to make the trip - but in the spacecraft 's reference frame, what distance do they travel?
Or, you know that in the Earth's reference frame, the distance traveled is 4 light years - but how long, in the Earth's reference frame, does it take to make the trip?
I'm sure you can set up an equation for either of these viewpoints. Remember that u is the speed of the ship in the Earth's reference frame, or equivalently the speed of the Earth (and Alpha Centauri) in the ship's reference frame. It'll be a little more complicated than just dividing distance by time to get the speed, but not much.
I have v = d /t
d = 4Ly
T = To / gamma
T = 3 / gamma
v = 4Ly / (3/gamma)
v = 4Ly * gamma / 3
is that right so far?
prime-factor said:
I have v = d /t
d = 4Ly
T = To / gamma
T = 3 / gamma
v = 4Ly / (3/gamma)
v = 4Ly * gamma / 3
No. You don't use length contraction and time dilation at the same time.
From the perspective of Earth, the spaceship clock runs slow. That's all you need. Length contraction will also mean the spaceship is shorter, but that does't change how far it has to go, which is still the same as far as Earth is concerned.
You can repeat the calculation from the perspective of the ship. In this case, there's no time dilation! As far as the ship is concerned, what you know is the time it take... but the distance is no longer 4 light years! It is distance contracted.
Which ever way you think of it you should get the same answer for the required velocity.
I am still not understanding.
Can you be more specific about what's confusing you?
sylas posted a pretty clear explanation and I'm not sure what could be added to it to help you understand better.
what i have is this:
u = d / t
d = 4Ly
Tearth = 3y / sqrt(1-u^2/c^2)
u = 4Ly sqrt(1-u^2/c^2)
3y
3u = 4c* sqrt(1-u^2/c^2)
9u2 = 16c2 (1 - u2/c2)
9u2 / 16c2 = (1 - u2/c2)
9u2 / 16c2 + u2/c2 = 1
u2/c2 ( 9/16 +1) = 1
u2/c2 = 1 / ( 9/16 +1)
u = 0.8c
How else do I go about it?, that's what i do not understand.
OK... we'll do it first from the perspective of someone on Earth.
You see a star that is at a distance of 4 light years. You have a spaceship that moves with some velocity v.
How long does it take the spaceship to get there, in terms of v, as measured on Earth? Forget time dilation. This is time as far as you are concerned, on Earth. You don't need any relativity for this step.
Write this down, as an expression in terms of v, even if you can't do anything else as yet.
Now... the next step. How long does it take on board the spaceship? Write this down, using the total time from the previous step, and a time dilation factor.
Finally... what you have just written down is equal to 3 years. Solve for v.
OK... I see you have already done this. Well done.
Now you want to do it all again, but this time from the perspective of someone on board the spaceship!
This time, the spaceship clock reads 3 years for the trip. They are traveling at velocity v. So what is the distance they must have traveled? This is an expression, in terms of v.
Now this distance is 4 light years, contracted from the point of view of the spaceship. Write down the expression, in terms of v, for distance.
You now have ANOTHER equation you can solve for v. You should get the same answer as last time!
Cheers -- sylas
Okay. I think I understand you:
t = 3yrs, velocity = u
therefore, d = 3years*u
Now for length contraction: L = Lo sqrt (1 - u^2/c^2), Lo = 4Ly* sqrt (1 - u^2/c^2)
3y*u = 4Ly* sqrt (1 - u^2/c^2)
3*u = 4c* sqrt (1 - u^2/c^2)
and we get u = 0.8c, like before
That's it! This is a great example to show that time dilation and length contraction are opposite sides of the same coin.
From Earth's perspective, the spaceship moves 4 light years in 5 years; but with time dilation the pilot only ages 60% of 5 or 3 years.
From the spaceship perspective, the distance is contracted to 60% of 4, or 2.4 light years. The star is approaching at 80% light speed, and it arrives in 2.4/0.8 or 3 years.
In either case, the pilot ages 3 years for the trip.
Cheers -- sylas
Thank you very much.
