Change of energy under charge conjugation
The discussion revolves around the concept of charge conjugation and its implications for energy in quantum systems, particularly in the context of electric fields and associated quantum numbers. Participants explore the theoretical framework and implications of charge conjugation, parity, and related operators.
  • Some participants question how energy can remain unchanged under charge conjugation, especially when considering charged particles in electric fields.
  • Others argue that the electric field also changes under charge conjugation, which maintains the overall energy balance.
  • There is a discussion about the implications of parity on energy invariance, with some suggesting that the direction of the electric field changes but not its strength.
  • Participants express confusion about how flipping quantum numbers under charge conjugation does not affect energy, leading to further exploration of operators that might change energy.
  • Some participants propose that a scale change operator could alter electromagnetic energy, raising questions about the nature of operators that affect energy.
  • Clarifications are made regarding the definition of charge conjugation, emphasizing that it involves flipping all internal quantum numbers but does not impact mass, energy, momentum, or spin.
  • There is a discussion about the relationship between lepton number, baryon number, and charge, with some participants noting that not all quantum numbers are related to charge in the same way.
Participants express differing views on the implications of charge conjugation for energy, with no consensus reached on how various quantum numbers interact with energy changes. The discussion remains unresolved regarding the specific effects of charge conjugation and related operators.
Participants highlight limitations in understanding how different quantum numbers contribute to energy, particularly in relation to charge and other properties. There is an acknowledgment of the complexity of the relationships between these concepts.
krishna mohan
I was going through an article on antiparticles:
http://www.statemaster.com/encyclopedia/Antiparticles
The article mentions that energy is unchanged under charge conjugation among the CPT operations.
I do not understand this. Shouldn't a charged particle in an electric field have a change in energy under charge conjugation?
The electric field would also change under charge conjugation, and the energy would stay the same.
Well..yes..that is fine..
so..you mean to say that when I apply charge conjugation operation, I should act it on everything in the system, including the source of the electric field?
But what about parity? Unless we have the special case where the electric field is invariant under parity, how can one say that the energy will be invariant under parity?
The strength of the electric field won't change under parity, just its direction.
Thanks...now I understand how energy is unchanged under charge conjugation when we consider electric charge...but charge conjugation here means flipping all the associated quantum numbers...how can we say that none of these changes will affect the energy??
Let's turn it around. Try and write down some operator that does change the energy.
Do you mean to say that there are no operators that change energy?? Can that be proved??
What about, say, a scale change operator, which scales all distances in the system by a constant factor? Assuming that the electromagnetic interactions are between point charges, in which case it seems somewhat logical to assume that the charge will not be changed, we will have a change in the electromagnetic energy of the system.
A second ago you were talking about the charge conjugation operator.
charge conjugation flips the charge quantum number, no other.
where did you learn to do charge conjugation? :P
I have thought of this operator because I thought that is what you instructed me to do..or did I misinterpret your post?
I read about charge conjugation in Griffiths Elementary Particles: sec 4.7...
You can also find the definition at http://hyperphysics.phy-astr.gsu.edu/HBASE/Particles/cpt.html
The definition says you have to flip all the internal quantum numbers..
Read carefully:
In quantum mechanical systems, charge conjugation has some further implications. It also involves reversing all the internal quantum numbers like those for lepton number, baryon number and strangeness. It does not affect mass, energy, momentum or spin.
Lepton number, baryon number and strangeness etc are related to charge. The others are not.
Yes..I have read that..but what I wanted was an explanation for the statement that the energy does not change..Now can I say this..that out of lepton no,baryon no, charge etc..only charge couples with a field to give contribution to the hamiltonian..and through this thread, I have come to understand how flipping the charge does not change the energy..but am confused by the last line..
What do you mean when you say lepton no etc are related to charge?
positive electron lepton number is just a fancy way to say "negative electrical charged"
Hmm..not really ..consider the neutrino..it has positive lepton no...an antineutrino has negative lepton no..but both of them are chargeless...
Clarification: In the last post no stands for number..
Well their lepton number is then related to another charge (like weak charge)
  • · Replies 21 ·
  • · Replies 21 ·
