Solving a Tensor Field: Divergence of P = 0
The discussion focuses on solving the divergence of a spherically symmetric tensor field represented in dyadic form as P(r) = P_n(r)𝑒_r𝑒_r + P_t(r)(𝑒_θ𝑒_θ + 𝑒_ϕ𝑒_ϕ). The key conclusion is that the condition for the divergence of P to vanish leads to the equation d/dr(r² P_n(r)) = 2r P_t(r). Participants emphasize the importance of using the correct product rule for divergence in dyadic notation, which simplifies the calculation and avoids common pitfalls associated with tensor divergence.
  • Understanding of tensor calculus, specifically second rank tensors.
  • Familiarity with dyadic notation and its application in vector fields.
  • Knowledge of divergence operations in spherical coordinates.
  • Basic principles of vector calculus, including the product rule for divergence.
  • Study the properties of second rank tensors in physics and engineering contexts.
  • Learn the application of dyadic notation in tensor analysis.
  • Explore divergence operations in spherical coordinates with examples.
  • Review vector calculus product rules, focusing on their extensions to tensor fields.
Mathematicians, physicists, and engineers working with tensor fields, particularly those involved in fluid dynamics or continuum mechanics, will benefit from this discussion.
Päällikkö
The following isn't actually a homework problem, but this seems to be the natural place to ask questions of this sort. Without further ado,
I have a spherically symmetric tensor field, which is written with the help of dyadics as
[tex]P(r) = P_n(r)\mathbf{e}_r\mathbf{e}_r + P_t(r)(\mathbf{e}_\theta\mathbf{e}_\theta+\mathbf{e}_\varphi\mathbf{e}_\varphi)[/tex]
From the condition that the divergence of P vanishes, I am to deduce that
[tex]\frac{d}{dr}(r^2 P_n(r)) = 2r P_t(r)[/tex]
As I've got little to no experience with tensors (especially when they're in dyadic form), I'm at a loss here.
For a vector field A one would calculate the divergence as
[tex]{1 \over r^2}{\partial \left( r^2 A_r \right) \over \partial r} + {1 \over r\sin\theta}{\partial \over \partial \theta} \left( A_\theta\sin\theta \right) + {1 \over r\sin\theta}{\partial A_\phi \over \partial \phi}[/tex]
I tried throwing stuff into here, and ended up with nonsense:
[tex]\frac{d}{dr}(r^2 P_n(r)) + \cot(\theta) r P_t(r) = 0[/tex]
I suppose the divergence could be calculated, in tensor terminology, as the contraction of P with the covariant derivative. This would lead to three equations, which I couldn't get to give the wanted result.
As I've got little to no experience with tensors (especially when they're in dyadic form), I'm at a loss here.For a vector field A one would calculate the divergence as
First off, it's important to notice that the divergence of a second rank tensor will be a vector.
What you seem to have done is say that
[tex]\mathbf{\nabla}\cdot P(r)=\mathbf{\nabla}\cdot\left(P_n(r)\mathbf{e}_r + P_t(r)(\mathbf{e}_\theta+\mathbf{ e}_\varphi)\right)=0[/tex]
(from which you obtain [itex]\frac{d}{dr}(r^2 P_n(r)) + \cot(\theta) r P_t(r) = 0[/itex])
Of course, this is utter nonsense.
Since you are given [itex]P(r)[/itex] in dyadic form, the easiest way to compute its divergence is probably to continue working in dyadic form and make use of the following product rule (which is a natural extension for the usual vector calculus rule involving the divergence of the product of a scalar and a vector):
[tex]\mathbf{\nabla}\cdot (\mathbf{A}\mathbf{B})=\mathbf{B}(\mathbf{\nabla}\cdot \mathbf{A})+\mathbf{A}\cdot(\mathbf{\nabla}\mathbf{B})[/tex]
[tex]\implies \mathbf{\nabla}\cdot \left[ P_n(r)\mathbf{e}_r\mathbf{e}_r + P_t(r)(\mathbf{e}_{\theta}\mathbf{e}_{\theta}+\mathbf{e}_{\varphi}\mathbf{e}_{\varphi}) \right] = \left[\mathbf{e}_r (\mathbf{\nabla}\cdot \mathbf{P_n(r)\mathbf{e}_r})+\mathbf{P_n(r)\mathbf{e}_r}\cdot(\mathbf{\nabla}\mathbf{e}_r)\right][/tex]
[tex]+ \left[\mathbf{e}_\theta (\mathbf{\nabla}\cdot \mathbf{P_t(r)\mathbf{e}_\theta})+\mathbf{P_t(r)\mathbf{e}_\theta}\cdot(\mathbf{\nabla}\mathbf{e}_\theta)\right] + \left[\mathbf{e}_\varphi (\mathbf{\nabla}\cdot \mathbf{P_t(r)\mathbf{e}_\varphi})+\mathbf{P_t(r)\mathbf{e}_\varphi}\cdot(\mathbf{\nabla}\mathbf{e}_\varphi)\right][/tex]
The desired result then follows by inspection of the radial component of [itex]\mathbf{\nabla}\cdot P(r)[/itex].
