Exploring Froth Flotation & Negative Energy of Activation
Froth flotation is an essential ore concentration technique utilized for extracting metals from hydrophobic sulfide ores, such as iron and copper pyrites. The process involves grinding crude ore into a fine powder, mixing it with water and specific reagents, and introducing air to create bubbles that carry mineral particles to the surface froth, while waste material settles below. Negative energy of activation refers to an apparent phenomenon in chemical kinetics where the reaction rate depends on the equilibrium constant of the rate-determining step, particularly in exothermic reactions, leading to a decrease in the apparent rate constant with increasing temperature.
  • Understanding of froth flotation techniques and reagents
  • Knowledge of chemical kinetics and activation energy concepts
  • Familiarity with hydrophobic sulfide ores
  • Basic principles of thermodynamics related to reaction rates
  • Research the specific reagents used in froth flotation processes
  • Study the kinetics of exothermic reactions and their impact on activation energy
  • Explore advanced techniques in ore concentration beyond froth flotation
  • Investigate the role of temperature in chemical reaction rates and equilibrium constants
Chemical engineers, metallurgists, and researchers in materials science focusing on metal extraction and reaction kinetics.
Evil
does anyone here has any idea what is froth flotation(in extraction pf metals) and negative energy of activation( as in chemical energetics)?
thanks for any input.
Chemistry news on Phys.org
Froth flotation is an ore concentration technique commonly used with (hydrophobic)sulfide ores (such as iron or copper pyrites). Crude ore is ground to a fine powder and mixed with water, frothing reagents, and collecting reagents. When air is blown through the mixture, mineral particles cling to the bubbles, which rise to form a froth on the surface. The waste material (gangue) settles to the bottom. The froth is skimmed off, and the water and chemicals are distilled or otherwise removed, leaving a clean concentrate.
For more discussion, see http://www.engr.pitt.edu/chemical/undergrad/lab_manuals/flotation.pdf
Negative Activation is only an apparent effect, it is not a real quantity. Very rarely, in reactions that go through some kind of intermediate, the reaction rate is found to be dependent on the equilibrium constant of the rate determining step. If this step is exothermic, the equilibrium constant decreases with increasing temperature. So, even though the rate constant increases with increasing temperature (as it should - this is a sign of positive activation energy), the product of the rate constant and equilibrium constant (or apparent rate constant) may be decreasing with increasing temperature. This is what is referred to as negative activation.
The oxidation of NO to give NO2 is such a reaction.
See : http://www.rod.beavon.clara.net/nitrogenmonoxide.htm
  • · Replies 0 ·
