What causes the back emf in motors
  • Context: Undergrad
  • Thread starter Thread starter likephysics
    Back emf Emf Motors
The discussion centers on the causes of back electromotive force (emf) in brushless DC motors, exploring the roles of the rotating magnetic field, self inductance, and the interactions between these factors as the motor operates at varying speeds.
  • One participant suggests that the rotating magnetic field of the rotor induces an opposing emf as it cuts through the stator coils, which increases with speed, likening this to a generator effect.
  • Another participant agrees that the motor acts as a generator and notes that opposing currents limit the maximum RPM of the motor, while expressing uncertainty about the role of self inductance.
  • A different participant explains that a conductor moving in a magnetic field generates an opposing magnetic field, which they identify as back emf, asserting that without this effect, perpetual motion would be possible.
  • One participant reflects on self inductance effects occurring primarily when the rotor changes speed, indicating that current is highest when the motor starts but decreases as back emf increases, leading to a balance of input power and losses at top speed.
  • Another participant reiterates the previous point about self inductance, emphasizing that it occurs regardless of speed changes as long as there is movement relative to a magnetic field, and clarifies that movement, not necessarily speed changes, is required for inductance to occur.
  • A participant expresses agreement with a previous point but highlights potential confusion due to terminology, discussing self inductance related to changing current in the rotor and its effects during switching on or off, or when motor loading changes.
Participants express varying views on the contributions of the rotating magnetic field and self inductance to back emf, with some agreeing on certain aspects while others remain uncertain or contest specific details. The discussion does not reach a consensus on the exact mechanisms or their interplay.
Participants note that the understanding of back emf and self inductance may depend on specific definitions and interpretations of terms, as well as the conditions under which the motor operates.
likephysics
What causes the back emf in motors (brushless DC motors to be exact).
First thing is the rotating magnetic field of the rotor, which cuts the stator coils inducing an emf in the opposite direction. This would increase as speed increases. This is just a generator.
Second, what about self inductance. You are switching the stator coils at a higher rate to gain more speed. Self inductance would limit the voltage.
Do both together contribute to back emf?
Anybody?
as for the generator aspect, yes. the motor becomes a generator, and the opposing currents fight against one another, causing the dc motor to max out it RPMs. as for self inductance, i think so, but am not sure.
A conductor moving in a magnetic field will generate, by virtue of inductance, an opposing magnetic field.
This is back EMF.
If this were not the case, the conductor would rapidly accelerate and perpetual motion machines would be possible and the universe would simply not work as it does.
I am rusty on this but I think there are self inductance effects in the rotor only when it is changing speed i.e. when the current changes.The current has its highest value when the motor is switched on but reduces as the speed and the back emf increases.When it reaches a top speed the input power is equal to the sum of the useful output power(work done per second against the back emf) and the joule heating
(I^2R)power losses.
(I^2R)power losses.
The VALUE, or amount, of inductance does change with the changing speeds of the rotor.
But inductance will occur regardless of speed changes.
As long as there is ANY movement of a conductor relative to a magnetic field(or vice-versa), inductance will occur.
Speed changes, as such, are not required. Movement is, even if it is a smooth constant speed.
Hopes this makes any sense.
I agree pallidin but I think we are at cross terms because of the terminology used.In addition to the inductance you refer to there is self inductance due to the changing current in the rotor itself and this sort of inductance does not need something else providing an external magnetic field.If we have say a d.c.circuit and switch it on, the current does not rise instantaneously to its final steady value but there is a delay due to the growing field around the circuit elements generating a back emf,this opposing the rising current.When you switch off the collapsing field tries to maintain the current.What you said is right but there will be self inductance effects when the rotor speed and current changes i.e. at switch on or off or when the motor loading changes.I think.
  • · Replies 22 ·
