Thread Closed
Torque on Baseball going through pitching machine
Share Thread Thread Tools
May29-09, 10:14 PM   #1
I am designing a shaft for a pitching machine that uses a spinning tire to accelerate a ball and must determine the torque acting on the shaft when a ball goes through the machine. A 1/4 horsepower motor is spinning an 8 inch tire at 1900RPM, constant angular velocity. Weight of baseball is 5.25oz (.328lb). What is the force that is imparted on the ball tangent to the wheel and with what velocity does it exit with? I know degrees over which the ball is acted on by the tire as .581radians.
2. Relevant equations
I am unsure of which equations will be relevant. Maybe vf^2=vo^2 +2as, Torque =Force x Radius, Power = omega(angular velocity) x Torque, F= ma
3. The attempt at a solution .
The ball is acted on by the tire at arc length s. By using s=r*theta, I get s to be .059m. But the problem where I am stuck is how do I incorporate the rotation of a tire to the acceleration of the object. Once I find this acceleration, then I can easily back out the tangential force, torque and resulting velocity. Please feel free to change units if you prefer. Thanks for your help!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Thread Closed
Thread Tools
Similar Threads for: Torque on Baseball going through pitching machine
Thread Forum Replies
Physics of baseball pitching General Physics 2
Torque on a baseball bat Introductory Physics Homework 1
Material in machine tool body (milling machine) Materials & Chemical Engineering 0
Aerodynamics: Wing Pitching Moment Aerospace Engineering 4
