Thread Closed
Complex series: Circle of convergence
Share Thread
May30-09, 10:06 AM   #1
Hi all.
Lets say I have a complex power series given by
[tex]
\sum_{n=0}^\infty c_nz^n,
[/tex]
where z is a complex number and c is a complex constant. Inside its circle of convergence, I can differentiate it leading to
[tex]
\sum_{n=0}^\infty c_nnz^{n-1} = \sum_{n=0}^\infty (n+1)c_{n+1}nz^{n}.
[/tex]
If I want to find the circle of convergence for this series, then I can use the ratio test
[tex]
\frac{1}{R} = \mathop {\lim }\limits_{n \to \infty } \left| {\frac{{a_{n + 1} }}{{a_n }}} \right|.
[/tex]
I have two questions for this:
Question #1: Does the ratio test give me the same answer regardless of I substitute e.g. n -> n+3? I.e., is it correct that
[tex]
\mathop {\lim }\limits_{n \to \infty } \left| {\frac{{a_{n + 1} }}{{a_n }}} \right| = \mathop {\lim }\limits_{n \to \infty } \left| {\frac{{a_{n + 3} }}{{a_{n + 2} }}} \right|.
[/tex]
Personally, I think it does not matter, because we let n go to infinity.
Question #2: Does the ratio test only work for power series that go from n=0 to infinity, or do they also work if n start at e.g. 1 or -1?
Thank you very much in advance.
Best regards,
Niles.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
May30-09, 11:50 AM   #2
Well the ratio test is typically derived from comparison to a geometric series. Moreover, one way to derive the comparison test is based on the monotone convergence theorem applied to partial sums. So I think you're right on both counts since only long term behavior matters. Especially for question 2, remember that including or excluding a finite number of terms in an infinite series does not affect convergence.
May30-09, 01:09 PM   #3
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Hi Niles!
Quote by Niles View Post
[tex]
[/tex]
Your intuitive suspicions are completely correct …
limiting behaviour is only affected "near" the limit …
what happens at the other end doesn't matter!
So yes, to both #1 and #2.
Thread Closed
Similar discussions for: Complex series: Circle of convergence
Thread Forum Replies
Convergence/Divergence of Given Series Using Alternating Series test. Calculus & Beyond Homework 2
Circle in the complex plane General Math 0
complex circle Precalculus Mathematics Homework 28
Complex series convergence on boundary Calculus 0
A complex circle Calculus & Beyond Homework 29
