Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > Set Theory, Logic, Probability, Statistics
Reply
image formal proofs, where....? Share It Thread Tools Search this Thread image
Old May30-09, 06:57 PM                  #1
tgt
tgt is Offline:
In which fields of maths are formal proofs used often?
Old May30-09, 07:05 PM                  #2
CRGreathouse
CRGreathouse is Offline:
Recognitions:
Homework Helper Homework Helper
Re: formal proofs, where....?
Foundations of mathematics (logic). They're really not used elsewhere!
Old May30-09, 08:59 PM                  #3
mXSCNT
mXSCNT is Offline:
Outside of mathematics, they are used in computer science in the formal verification of computer programs, automatic theorem proving/checking, and in the AI field of expert systems.
Old May30-09, 10:37 PM                  #4
tgt
tgt is Offline:
But not in all of mathematical logic? They are used in proof theory. Where else?
Old May31-09, 03:44 AM                  #5
HallsofIvy
PF Mentor
HallsofIvy is Offline:
Precisely what do you mean by "formal" proofs? The responders here may not mean the same thing you do.
Old May31-09, 04:47 AM                  #6
Edgardo
Edgardo is Offline:
The December issue of Notices of the American Mathematical Society may be interesting for you:
http://www.ams.org/notices/200811/
Old May31-09, 10:05 AM                  #7
tgt
tgt is Offline:
I would mean the kind that most people (at least all the logicians) would regard as formal.
A formal proof or derivation is a finite sequence of sentences (called well-formed formulas in the case of a formal language) each of which is an axiom or follows from the preceding sentences in the sequence by a rule of inference. The last sentence in the sequence is a theorem of a formal system.
In other words where everything in the proof is 100% rigorous.
Old May31-09, 10:27 AM                  #8
matt grime
Math Guru 2008
matt grime is Offline:
Recognitions:
So you think all other mathematics is unrigorous and doesn't follow these rules?
Old May31-09, 11:00 AM                  #9
HallsofIvy
PF Mentor
That is NOT what "most people (at least all the logicians)" would consider "formal". For a logician, certainly, a "formal proof" would require much more than it be "100% rigorous".
Old May31-09, 10:51 PM                  #10
mXSCNT
mXSCNT is Offline:
A proof can be considered rigorous if all the reasoning used in it is justified, so that its conclusions necessarily follow from its assumptions--even if it is not a fully formal derivation. In an informal proof, a mathematician might use shortcuts like "so by X, we get..." and give the result, omitting some calculation. So long as a competent reader could do the calculation himself and get the same result without too much trouble, the proof can be considered "rigorous."
Old Jun1-09, 01:06 AM                  #11
tgt
tgt is Offline:
All others are incomplete (non technical word). Incomplete might mean not giving derivations when it should.
I've mixed this notion of completeness into the word rigour. In fact this mixing is allowed if one is to add the word formal:
Formal rigour is the introduction of high degrees of completeness by means of a formal language where such proofs can be codified using set theories such as ZFC (see automated theorem proving).
http://en.wikipedia.org/wiki/Rigour
Old Jun1-09, 02:17 AM                  #12
matt grime
Math Guru 2008
Recognitions:
No (correct) proofs are incomplete, or they are not proofs. The proof of the theorem will follow from the hypotheses of the theorem. Whether or not the hypotheses are ever satisfied is essentially unimportant to whether or not the proof is rigorous.
Of course a writer may omit 'obvious' steps.
If you're going to assign personal meanings to words that are already quite flexible who knows what kind of answer you're going to get.
No one is going to prove much from the axioms of ZFC, since one only ever does maths in a model of ZFC (unless one is doing abstract set theory) where many theorems are true and can't be proven from the axioms, either because they do not follow from the axioms or because they're so far removed as to make its deduction practically impossible.
Old Jun1-09, 05:41 AM                  #13
tgt
tgt is Offline:
That's what I meant by saying a proof is incomplete.
I assume that when you say some theorem cannot be proven from ZFC it's because extra axioms are needed.
Old Jun1-09, 01:42 PM                  #14
matt grime
Math Guru 2008
Recognitions:
The proof is not incomplete - the reader is supposed to do the steps to verify it.
The axioms of ZFC are very weak, in some sense. You cannot prove a lot directly from them: they don't even assert that the real numbers exist, so you're not going to deduce any analysis from them even. ZFC doesn't even imply the existence of an uncountable set (Skolem's paradox states something like any finitely axiomatized system has a countable model). You must know of Goedel's theorem as well.
Old Jun1-09, 02:14 PM                  #15
Preno
Preno is Offline:
False.
Of course they do. For example, the powerset of N is uncountable, because P(X) is always larger than X.
Old Jun1-09, 03:49 PM                  #16
matt grime
Math Guru 2008
Recognitions:
Oh boy. Did you even look up Skolem's paradox? All that ZFC implies is that there is no bijection between P(N) and N, where we take N to be the inductive set that ZFC states exists. Note that this requires you to define the power set (ZFC doesn't say what it is) and also note that all we can say is that there is no bijective function from P(N) into N in that model. That is not the same as stating that there is no bijection in any model at all. "Larger" is also a completely undefined term in your post too.
image image
Reply
Thread Tools
Similar Threads for: formal proofs, where....?
Thread Thread Starter Forum Replies Last Post
formal charge Dell Other Sciences 3 Feb10-09 04:03 PM
Nightmares with formal proofs in set theory JasonJo Precalculus Mathematics 3 Mar26-06 12:55 PM
formal charge zhen Other Sciences 6 Dec14-05 05:52 PM
Proofs...advice/places to find more practice proofs Mark Introductory Physics 2 Sep12-04 08:38 AM
Formal Proof StephenPrivitera General Math 15 Aug2-03 12:07 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
