| Thread Closed |
Why does fly fly? |
Share Thread | Thread Tools |
| Jun4-09, 11:21 AM | #18 |
Why does fly fly?Work being done would be an effect of a helicopter rotor or propeller blade when you are using momentum theory. (PS, I was giving warren a hard time about what he said for the forces on a wing. He's right, I was nitpicking). |
| Jun4-09, 06:46 PM | #19 |
Recognitions:
The "work being done" issue is mentioned in this Nasa article on propellers, and exit velocity. Not covered is what is happening at the outer edges of the decreasing diameter funnel of the main air stream. "But at the exit, the velocity is greater than free stream because the propeller does work on the airflow. We can apply Bernoulli'sequation to the air in front of the propeller and to the air behind the propeller. But we cannot apply Bernoulli's equation across the propeller disk because the work performed by the engine (by the propeller) violates an assumption used to derive the equation." http://www.grc.nasa.gov/WWW/K-12/airplane/propanl.html |
| Jun4-09, 07:06 PM | #20 |
| Jun4-09, 09:21 PM | #21 |
| Jun5-09, 12:32 AM | #22 |
| Jun5-09, 12:44 AM | #23 |
I'm in Houston, where are all you astronauts and flight jocks to back me up with a better explanation? |
| Jun5-09, 01:22 AM | #24 |
Forum Side note: why do you we have to have this discussion about how an airplane wing flies for the millionth time around here. Someone should just put a sticky that stays STOP ASKING about Bernoulli and wings. Good god, a thousand and one threads on this gets old fast. The OP didn't even ask about Bernoulli, so why are we even talking about it? |
| Jun5-09, 05:07 AM | #25 |
Recognitions:
M2-F2 glider: ![]() M2-F3 rocket powered version (max speed mach 1.6):
| Jun5-09, 07:10 AM | #26 |
| Jun5-09, 11:10 AM | #27 |
| Jun6-09, 06:09 AM | #28 |
| Jun6-09, 06:14 AM | #29 |
Recognitions:
The M2-F2 and M2-F3 are good examples to "disprove" equal transit theory as the cause of lift, and I just find them interesting, as they are fairly unique. I rotated the picture 2 degrees right to make the ground appear level, still the upper surface of the m2-f2 is nearly horizontal, but it could be in a "flare" since it's landing, but the wheels are still up, so even though it's fairly low, it's got some gliding time left to deploy the landing gear. ![]() Also the top surface isn't completely flat, it tapers at the tail, but the main point is shape of the lower surface, and the fact that the bottom surface is the "longer path".
| Jun7-09, 09:36 PM | #30 |
There is a two day seminar of flapping wing flight on campus tomorrow and the day after that I will be attending. I'll report anything interesting. Here is the schedule
| Jun7-09, 09:39 PM | #31 |
Despite this, it is a very interesting aircraft design! It looks like a delta wing with the pilot all the way forward for stability in pitch. |
| Jun7-09, 09:59 PM | #32 |
Recognitions:
| Jun7-09, 10:40 PM | #33 |
*The only real "approximation" is that the gas particles follow a continuum. As for Actuator Disc Theory, tom-a-to, to-ma-to. |
| Jun8-09, 01:54 PM | #34 |
I left half way into the talks because I have work to do. But what I did see was pretty interesting. A guy from CalTech had optical sectioning images of a fly. Basically, they use special infrared laser beams to scan the fly and you can see all the internal structure of the fly just like a 3d MRI. The fly has two muscles that cause the complex flapping motion. One main muscle always powers the flies wings, while these two muscles adjust the tension, and thus the equivalent spring constant to change the flapping properties. Pretty non-intuitive. There were also a video of a honey bee inside a wind tunnel given a wind gust disturbance, and a high speed strobe video of a fly with a piece of string tethered onto its back to keep it stationary.
| Thread Closed |
| Thread Tools | |
