| Thread Closed |
Can we prevent tornadoes? |
Share Thread |
| May24-11, 08:27 AM | #35 |
Can we prevent tornadoes?To power LEDS, the rotors would power a small electic generator. The generator would provide resistance on the rotors. Since the devices are not attached to anything, the rotors would be just as happy to not spin at all, the devices themselves would spin, rotor and all, rather than work against the resistance. You don't need to convert the energy into any harmless form. Once you extract the energy with any form of resistance at all, (such as flat objects), the tornado won't be able to make use of it. So what you're really doing is simply tossing inert mass into the tornado, whose inertia alone will extract wind energy. However, now your tornado becomes a machine gun of 200mph bullets. |
| May24-11, 08:51 AM | #36 |
Mentor
| May24-11, 02:08 PM | #37 |
http://www.weather.com/outlook/weath...nts_2011-05-23
A senior meteorologist delivers an explosive forecast for the next two days. "the potential atmospheric setup is at least on par, if not more explosive than that May 3, 1999 event!" He is discussing detailed atmospheric conditions indicating to him the potential of an F5 tornado in the vicinities of Wichita, Oklahoma City and Tulsa beginning Tuesday, May 24, 2011. |
| May24-11, 02:30 PM | #38 |
Seriously, the only potentially available strategy that has any possibility of someday being practical is some form of cloud seeding of likely "super cells" before funnel clouds actually form. Even then there are real questions about what agents to use (dry ice?) both for effectiveness and environmental safety. The logistics would also be very tricky. At present this strategy is not very promising. Clouding seeding and tornado prevention is briefly discussed in this link.
http://www.spc.noaa.gov/faq/tornado/ |
| May24-11, 08:32 PM | #39 |
Respectfully yours, Steve |
| May24-11, 10:13 PM | #40 |
We have to nuke 'em and we have to nuke 'em now!
| Jun1-11, 01:46 PM | #41 |
Water. Adding water to a functioning tornado will suck out energy.
How to add it? |
| Jun1-11, 02:31 PM | #42 |
Mentor
You do also know that tornadoes form from severe rain storms and hurricanes? Please do not post without linking to the peer reviewed or scientifically acceptable studies that back you up. |
| Jun1-11, 03:06 PM | #43 |
Since scientific "truths" are only social conventions, I believe the most effective way to eliminate tornadoes is to differentiate "wrongly", so that the Coriolis force disappears.
Very bad force, that one.. |
| Jun1-11, 04:57 PM | #44 |
Waterspouts are not as dangerous as terrestrial tornadoes.
Water, added to a "dry" tornado, absorbs energy. Stop being condescending ; particularly when you have not thought through the response. |
| Jun1-11, 05:06 PM | #45 |
Admin
Uh oh.
<takes pop corn and coke> |
| Jun1-11, 05:52 PM | #46 |
Mentor
Borek, hand me some popcorn. Some vaild tornado sources. http://www.spc.noaa.gov/faq/tornado/#Climatology http://www.nssl.noaa.gov/faq/faq_tor.php |
| Jun1-11, 06:57 PM | #47 |
I have been unable to find a good source (including Evo's links) that says dumping water into a tornado will make it stronger, or that dumping water into it will make it weaker.
While true, tornadoes do form from severe active thunderstorms, I don't know if that is convincing enough to conclude that adding lots of water to one would have an enhancing effect. For example, if the water happened to be cooler (because it is being artificially added, as opposed to being evaporated naturally), it could - at least conceivably - have a diminishing effect. I'd say the jury is out until someone can quote a good source on it. |
| Jun1-11, 06:57 PM | #48 |
"Post the acceptable scientific sources to back your self up."
(Groan) The last refuge of the scoundrel is the desire to request references. Footnote yourself, m'dear. |
| Jun1-11, 07:03 PM | #49 |
: and then takes one big step away from artist : |
| Jun1-11, 07:31 PM | #50 |
Water, when subjected to the low pressure of a tornado, turns into water vapor.
So a hypothetical tornado that passes over a pond sucks up water, expending energy. The water goes through a state change and becomes a gas. Does this cool water have an effect on the tornado???? |
| Thread Closed |
Similar discussions for: Can we prevent tornadoes?
| The physics of tornadoes and interior pressure | General Physics | 1 | ||
| WHat causes tornadoes and hurricanes. | Earth | 1 | ||
| New Theory on why tornadoes occur. | Classical Physics | 2 | ||
| connection between hurricanes and tornadoes | General Physics | 6 | ||
