What is the value of c for a shaded area of 110 between two parabolas?
  • Thread starter Thread starter intelli
    Area
The discussion revolves around finding the value of c for the area enclosed by two parabolas, y = x² - c² and y = c² - x², to equal 110. Participants are exploring the mathematical reasoning and calculations involved in determining this value.
  • Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss their attempts to calculate c, with one stating a value of 3.49 and others suggesting it might be 3.45. Questions arise about the methods used to arrive at these values, including the integration process and the interpretation of the area calculation.
There is ongoing exploration of the calculations and methods used to find c, with some participants expressing uncertainty about their approaches. Guidance is offered regarding the integration setup and the interpretation of the curves involved. Multiple values are being considered, and participants are questioning the accuracy of their results.
Participants mention the need to express the result exactly, and there is a reference to a similar problem discussed by a professor, which adds to the complexity of the current problem. Some participants express confusion about whether their mathematical setup is correct.
intelli
Find c>0 such that the area of the region enclosed by the parabolas y= x^2-c^2 and
y = c^2-x^2 is 110
what is value of c
i got 3.49 and it is wrong i don't understand how to do this problem any help would be greatly appreciated
y = c^2-x^2 is 110
what is value of c
How did you get 3.49? Show us your work please.
It's hard to tell what you did wrong if you don't show us how you got 3.49.
ok
x = + c , -c
a = 4 integral 0 to c (c^2-x^2)dx
110 = 4 times [ c^2*x-(1/3)x^3] limit 0 to c
110 = (8/3) c^3
c = 3.45
ok
x = + c , -c
110 = (8/3) c^3
c = 3.45
I get 3.45... as well. But that's not the same as 3.49. Maybe they want you to express it exactly using a cube root?
no i tried that it doesn't work
I get 3.4552116... That's not quite 3.45 to 3 sig figs.
no i tried all that and it still doesn't work is the math correct the formula i mean i don't even know if i am even doing the problem right
It looks fine to me.
I agree. Ask the prof, and please post the final answer back here. Thanks.
Well i he did a similar problem but i still don't get it
this is what he did y = x^2 -c^2
y = (0)^2-C^2
y = c^2-X^2
y = c^2-(0)
y = c^2
c^2-X^2=x^2-C^2
2c^2 = 2x^2
+-c = X
area integral a to b (y top - y bottom)dx
110 = integral -c to c (c^2-x^2)-(x^2-c^2)
I think he is figuring out which curve is on top of the region (y=c^2-x^2) and which is on the bottom (y=x^2-c^2) and then the x boundaries +c and -c. He then subtracts the lower curve y from the upper curve y and integrates over the whole region at once (rather than doing the first quadrant and multiplying by 4, like you did). But if you do his final integral, you get (8/3)*c^3. Just as you did.
Dick said:
I think he is figuring out which curve is on top of the region (y=c^2-x^2) and which is on the bottom (y=x^2-c^2) and then the x boundaries +c and -c. He think subtracts the lower curve y from the upper curve y and integrates over the whole region at once (rather than doing the first quadrant and multiplying by 4, like you did). But if you do his final integral, you get (8/3)*c^3. Just as you did.
thx its right
  • · Replies 59 ·
  • · Replies 17 ·
