Simple problem that webassign keeps saying wrong
  • Thread starter Thread starter xX1SHOt
The discussion centers on a physics problem involving the average speed and acceleration of a nitrogen molecule, specifically addressing the calculations for average acceleration and force exerted on a wall. The participant calculated the average acceleration as approximately -3.722 x 10^15 m/s², but faced issues with Webassign indicating the answer had the wrong sign. For the force calculation, they derived a value of 483.86 N, which Webassign flagged as off by an order of magnitude. The participant received feedback that their approach to calculating force was incorrect due to improper unit handling.
  • Understanding of kinematic equations, specifically average acceleration calculations.
  • Familiarity with Newton's second law of motion (F = ma).
  • Knowledge of unit conversions and dimensional analysis in physics.
  • Experience with online homework systems like Webassign.
  • Review the derivation and application of the average acceleration kinematic equation.
  • Study the principles of dimensional analysis to ensure correct unit handling in calculations.
  • Learn about common pitfalls in online physics homework systems and how to troubleshoot them.
  • Explore additional resources on force calculations and their relation to acceleration in different contexts.
Students studying physics, particularly those tackling problems involving kinematics and forces, as well as educators looking to understand common student misconceptions in these areas.
xX1SHOt
1. Homework Statement
The average speed of a nitrogen molecule in air is about 670 m/s, and its mass is about (4.68 x 10^-26)kg.
(a) If it takes (3.60 x 10^-13)s for a nitrogen molecule to hit a wall and rebound with the same speed but moving in an opposite direction (assumed to be the negative direction), what is the average acceleration of the molecule during this time interval?
____________ m/s^2
(b) What average force does the molecule exert on the wall?
____________N
2. Homework Equations
Ok, here is the basic kinematic equation and force equation. I used both of these equations to talk to my professor after class 2 days ago to solve it and he got the same answer. I emailed him today and he said you use the average acceleration kinematic equation to solve it but that's what we did, i don't know if he doesn't remember or there is some secret one that i have never been informed of.
a)- (final velocity - initial velocity) / (change in time) = average acceleration
b)- (mass * average acceleration) / (change in time) = average force
3. The Attempt at a Solution
a) (-670-670) / (3.6 x 10^-13) = approximately (-3.722 x 10^15)m/s^2
Webassign's response: "Answer has wrong sign"
My next answer: ([positive now]3.722 x 10^15)m/s^2
Advice on tricky wording or problem or something?
b) [(3.722 x 10^15)*(4.68 x 10^-26)] / (3.6 x 10^-13) = 483.86 N
Webassign's response: "Answer is off by an order of magnitude"
My next answer: -483.86 N
Webassign's response: "Answer has the wrong sign"
Honestly this makes no sense but if anyone can help or gets a different answer you help would be greatly appreciated
For part a) I don't really see what's wrong either other then I got exactly -3.725 instead of your -3.722 but you noted it was approximate. For part b), you don't divide by the time interval. F = ma, and averages can take the place of instantaneous F, a. Remember to check your dimensions, your computation has units of kg*m/s^3 which is not a unit of Force.
Excellent point about b) i can't believe that i missed that one thank you very much. But you are saying that there is no explanation for a being wrong. and the .003 off shouldn't matter because as long as you are within 1% or the correct answer it will give it to me.
EDIT: Your help has been great can you look at my other problem as well:
https://www.physicsforums.com/showthread.php?p=2237013#post2237013
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 30 ·
