Understand Doppler Effect: Hubble & Stars Moving Away
  • Context: Undergrad
  • Thread starter Thread starter jakrabb
    Doppler Hubble
The discussion revolves around the application of the Doppler effect in understanding the movement of stars and galaxies, particularly in relation to redshift measurements. Participants explore how spectral lines are shifted due to relative motion and the implications of these shifts for determining velocities and directions of celestial objects.
  • Some participants explain that the Doppler effect causes a decrease in frequency for objects moving away and an increase for those moving towards the observer.
  • There is mention of the distinction between ordinary Doppler shifts and cosmological redshift, with the latter being attributed to the expansion of space over time.
  • One participant notes that the radial velocity measured is only in the direction toward or away from the observer, and that proper motion cannot be determined from Doppler measurements alone.
  • Another participant discusses the variability of the Hubble Parameter over time and its impact on the calculated velocities of distant objects.
  • Participants express uncertainty about the margin of error in measurements and whether different Doppler readings from various positions could provide more accurate directional data.
  • Gravity is mentioned as a factor that can also cause redshifting, adding complexity to the discussion.
  • There is a reference to the breakdown of Doppler formulae over large distances within the same coordinate chart.
Participants generally agree on the basic principles of the Doppler effect and its application to celestial observations, but there are multiple competing views regarding the implications of redshift, the accuracy of measurements, and the influence of various factors such as the Hubble Parameter and gravity. The discussion remains unresolved on several points, particularly regarding the interpretation of redshift data.
Limitations include the dependence on the definitions of radial velocity and proper motion, as well as the unresolved nature of the Hubble Parameter's value over time. The discussion also highlights the complexity of measuring velocities in the context of an expanding universe.
jakrabb
I am trying to understand how the doppler effect was used when determining that the other stars were moving away from us. I get that the spectral lines observed are shifted and by examining that data we can calculate how fast its moving and if it is towards or away from us. could anyone elaborate on this? can we actually tell a direction; is the margin of error large or small? ... i guess i just need more info to comprehend it all..
Astronomy news on Phys.org
Greetings !
Welcome to PF jakrabb ! :smile:
If the object moves away the frequency of the emmited
electromagnetic waves (light) will decrease (Doppler Effect),
if it moves towards us the frequency will increase.
The whole EM frequency range is called the electromagnetic
spectrum.
When we observe a star or some other distant object we take
the emission pattern that we would normally expect from such
an object and search for it along the observed EM spectrum.
Live long and prosper.
Originally posted by drag
Greetings !
spectrum.
Greetings also!
To add to what drag correctly stated, it must be remembered that the "velocity" change we see, toward or away from us, is radial velocity only. That is, straight-line toward or away from us. Any proper motion (sideways or at any angle) can't be determined. But, when the tilt angle of a particular galaxy is known, we can use the radial velocity and the tilt to get an actual velocity, for example star velocity around the galactic center. The Massive black hole in the center of M87, a giant elliptical galaxy, was determined (required) by this method of measuring the velocity of stars orbiting near the core.
Also, the "correct" velocity of distant objects depends greatly on the value of the Hubble Parameter used at the time. For years, a value of Hv was used at 55km/sec./Mpc. Then, everyone was using any value between 55 and 75. Now, with new discoveries and new data, the figure of Hv is settled on at 71km/sec./Mpc. I don't doubt that this figure will change also, but it seems to fit observations for now.
lines are shifted by two effects----ordinary doppler due to relative motion (visible e.g. in spectra of nearby stars) and cosmological redshift due to expansion of space (visible e.g. in spectra of distant galaxies)
the rate space is expanding has changed over the course of time and so the cosmological redshift cannot be ascribed to anyone particular radial velocity but must be related to how much space has expanded during all the time the light has been in transit
it may help to think of a distant galaxy as sitting still in the space around it---but that neighborhood of space is getting farther away from us
the standard formula for the cosmological redshift (as opposed to doppler) is in terms of a(temit) and a(trec) the scale-factor (indicating "size of universe" or "average distance between galaxies") at the time the light was emitted and at the time it was received.
1 + z = a(trec)/a(temit)
(see Eric Linder's online "cosmology overview" for this, or any of a bunch of other sources findable on google)
DOPPLER shift formula on the other hand is primarily for things in the same coordinate chart---same local coordinates----so that there is a well-defined radial velocity.
For things in the same locale, Special Relativity applies and we have the SR Doppler formula
1 + z = sqrt ((1 + beta)/(1 - beta))
here beta = v/c, the radial velocity expressed a fraction of light
this SR Doppler formula is approximately the same as a much simpler one without the square root:
1 + z = 1 + v/c
z = v/c
The approximation is fine as long as v/c is small, like 0.01 or less.
The sideways component of velocity (as contrasted with the radial component which Doppler indicates) has to be determined by different means, like noting a star's change in position over the course of years.
Any of this what you wanted?
thanks guys, that gets me started. and yes you were Very helpful marcus that is exactly the type of stuff i am looking for... i was trying to figure out if takeing different doppler readings from opposite sides of the sun might give different 'vectors' and give an idea of the true direction of a star
thanks :smile:
Gravity itself causes redshifting as well.
Doppler formulae can breakdown over distances covered within the same coordinate chart.
  • · Replies 48 ·
  • · Replies 43 ·
