Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > Special & General Relativity
Reply
image Black Hole Horizon Information Share It Thread Tools Search this Thread image
Old Jun15-09, 01:15 PM                  #1
Naty1
Naty1 is Offline:
Recognitions:
PF Contributor PF Contributor
Here's what for me was a fascinating (and straight forward) description of How Jacob Beckenstein concluded information is displayed on the horizon of the black hole. The formulas are so simple and the results so profound I wanted to post them here...I'd never seen this before...
This is excerpted from THE black hole WAR 2008, by Leonard Susskind, most of which appears around pages 151 to 155...
The most difficult conceptual idea for me is the starting point:
Beckenstein assumed a one bit photon falls into a black hole. To make the photon location as "uncertain" as possible, minimizing its information content, following Heinsenberg's uncertainty principle, he assumed the wavelength to about equal the Schwarzchchild radius, the longest feasible wavelength for capture to spread the photon to be as uncertain as possible. Susskind says longer wavelength photons would bounce off the horizon.
Beckenstein wondered how the size of a black hole would change if a single bit of information were dropped in...today we take for granted it's one Planck area, but how did he calculate that????? Here's the derivation:
To figure the increase in mass, let's figure the energy of the photon and then convert that to an equivalent mass.
Photon energy is E = hf and if wavelength is R[sub]s/SUB], from v = f x wavelength, frequency (f) is c/R[sub]s/SUB] so E = hf becomes hc/R[sub]s/SUB]. (1)
From E =mc2, dividing energy by c2 gives mass, so the change in mass becomes h/Rsc. (2)
The Schwarzschild radius is given by Rs - 2MG/c2 (3)
and substituting the above change in mass for the photon, substituting (2) in (3) increases the radius 2hG/Rsc3....
So we have a photon adding a bit (pun) of mass to a black hole. Plugging in all the numbers gives a radius increase of 10-72 meters....
Finally the (spherical) horizon area of a stable black hole is given by
A= 4(pi) Rs2 so if the radius increases by a power of -72, the area increases by a power of -70....
What a coincidence...that's Planck area!!!!! (the square of planck length of 10-35 meter) .... so adding one bit adds one Planck area to the horizon!!! It works for any size black hole.
Susskind concludes:
Somehow, hidden in the principles of quantum mechanics and the general theory of relativity there is a mysterious connection between indivisible bits of information and Planck sized bits (pieces) of area.
If anyone can explain a bit more about the logic underlying one bit per photon in this example, I'd appreciate it.
Old Jun15-09, 01:20 PM                  #2
MeJennifer
MeJennifer is Offline:
Re: Black Hole Horizon Information
That is not a coincidence at all, it simply follows from the applied formula.
Old Jul1-09, 11:33 AM                  #3
Jon_Trevathan
Jon_Trevathan is Offline:
Naty1 asked:
In black hole Wars, it is my recollection that Dr. Susskind, within the context of string theory, described each photon as a bit of string. Elsewhere in his book, it is my recollection that Dr. Susskind seemed to associate one bit of information to each dimensional twist and turn that the string might potentially manifest. Using an example that I recall in his book was limited to three spacial dimensions, I believe Dr. Susskind expressly associated two bits of information to each string loop. Based on the forgoing, I would have thought each photon might have been associated with two bits of information, and not just one.
Obviously, I am missing something important.
Help?
I recognize that strings are believed to be one-dimensional lines oscillating in eleven spacetime dimensions. If so, it would seem that a string might also twist and turn in any of the ten spacial dimensions that string theory allows. Would string theory's additional spacial dimensions increase the bits of information potentially associated with each sting loop; and by implication the bits of information each photon might possess? I recognize that Dr. Susskind's book provided very simplified descriptions and examples for readers with limited scientific backgrounds. However, I again feel that I am missing something important.
Further explanations from the readers of this forum would be very helpful.
Thank you.
Jon
Old Jul2-09, 09:30 AM       Last edited by Naty1; Jul2-09 at 09:44 AM..            #4
Naty1
Naty1 is Offline:
Recognitions:
Help?
That is actually a two dimensional lattice example on page 373....each link is two bits. He goes on to relate this to a black hole event horizon, also two dimensional...
You bring up a good point I had not thought about...maybe a photon present is a "1"; absence of a photon a "0"...
Old Jul2-09, 09:50 AM                  #5
George Jones
PF Mentor
George Jones's Avatar
George Jones is Offline:
Two comments:
1) An Introduction to Black Holes, Information, and the String Theory Revolution: The Holographic Universe by Susskind and Lindesay,
http://www.amazon.com/Introduction-I.../dp/9812560831,
is a (somewhat) short introduction to Susskind's ideas at about the senior undergrad/beginning grad student level;
2) the holographic principle is not universally accepted.
Old Jul2-09, 09:58 AM                  #6
Naty1
Naty1 is Offline:
Recognitions:
Great question. Stumps me...some thoughts....
Entropy: if considered as information and measured in bits which depends on the total degrees of freedom of matter/energy.....this seems to confirm your thought.
Holographic Principle: everything inside a region of space is described by information bits restricted to the boundary....seems to contradict. But what is the "boundary" of say ten dimensional space...a surface of 2 dimensions.... or 9 dimensions??
Additional dimensions: If compactified, I don't think strings would "fit"...quantum jitters would maybe go crazy due to confinement??...yet the extra dimensions supposedly provide strings with characteristic vibration modes....could be a source of additional bits....like different wrapping, for example....
Old Jul6-09, 06:28 AM                  #7
Jon_Trevathan
Thank you for your efforts.
If we are dealing with 10 spacial dimensions plus time (10+1 space), I believe the holographic principle requires the boundary to have 9 dimensions.
The more I have reflected on this question, the more I feel the answer must be Yes.
However, noting that in string theory each particle-type is manifested through a unique vibrational pattern within the string, it would seem possible that the strings associated with our observable photons vibrate such that only one or two bits of information are involved. I am not sure I like this explanation, but I think it could answer the question I posed.
Any ideas?
I recognize that there are a number of black hole theories. However, your observation about quantum jitters introduces an important observation. The Heisenberg uncertainty principle would seem to preclude a black hole singularity of infinite density. Dr. Susskind, in fact, makes this observation in the Black Hole wars. I can only presume that he and others properly considered the compact dimensions that String Theory seems to require.
Does anyone know what the maximum density of a black hole singularity is predicted to be (when the quantum jitters and the compacted dimensions are appropriately considered)?
It would be fascinating if the result corresponded with the Planck mass.
Again, any ideas?
image image
Reply
Thread Tools
Similar Threads for: Black Hole Horizon Information
Thread Thread Starter Forum Replies Last Post
Black Hole and the event horizon Charlie G Special & General Relativity 4 Feb19-09 08:18 AM
Black hole-event horizon life=games&math Astrophysics 25 Feb25-08 05:33 AM
Event horizon of a Black Hole tabchouri Special & General Relativity 11 Sep21-07 10:17 PM
Q: Black Hole Horizon mark_horn@sbcglobal.net General Physics 2 Aug27-07 06:00 AM
Black Hole Event Horizon JohnnyTheFox General Astronomy 2 Mar10-05 09:08 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
