Thanks for the help!
ZikZak:
In SR, the nonaccelerating twin will always be older, but that changes in GR. In GR, geodesics are still the paths of extremal aging, but because of curvature, that extremum need no longer be a maximum, and for orbiting bodies is frequently a saddle point.
With my very vague understanding of physics, let me see if I'm understanding you correctly. By saying that an orbiting body may be in a saddle point, are you saying that this means that acceleration in one direction will decrease aging, while acceleration in another direction will increase aging?
George Jones:
Short answer: a geodesics worldline from event p to event q has maximum elapsed proper time for all worldlines from p to q if and only if there are no conjugate points between p and q.
I think I'm getting you. If I want to go from Florida to Washington, there is a geodesic connecting them across the united states, and a geodesic connecting them going all the way around the planet. If I'm following the geodesic that goes all the way around the planet, it'll be longer than even a very twisty road that doesn't leave the united states.
In four dimensions, if I compare two curves beginning and ending on the same two points, the longer curve will have traveled through more space and less time. So a longer curve means aging less. If space itself is curved, it makes sense that I could draw a curve that doesn't follow a geodesic but is shorter than one that is a geodesic, and therefore I would be describing an accelerating object which is aging faster than an object in free fall.
Did I butcher that?
