I am looking for the B-field of a real coil.
  • Context: Graduate
  • Thread starter Thread starter 0xDEADBEEF
    B-field Coil
The discussion focuses on calculating the B-field of a real coil, specifically a straight piece of pipe with current density. It confirms that there is no analytical solution for the off-center field, but provides a closed-form solution for the on-axis field using the Biot-Savart law. The formula for the magnetic field along the axis is given as B_z(z) = (μ₀ n I / 2) (cos(α₁) - cos(α₂)), where α₁ and α₂ are angles related to the coil's symmetry. For a long solenoid, the magnetic field is independent of coil diameter, with practical examples provided for typical coil parameters.
  • Understanding of Biot-Savart law
  • Familiarity with magnetic field calculations
  • Knowledge of solenoid properties
  • Basic proficiency in calculus for integral evaluation
  • Study the derivation of the Biot-Savart law in detail
  • Research the properties and applications of solenoids
  • Explore numerical methods for calculating off-center magnetic fields
  • Learn about magnetic field measurement techniques, including Tesla meters
Physicists, electrical engineers, and students studying electromagnetism who are interested in magnetic field calculations and solenoid design.
0xDEADBEEF
I am looking for the B-field of a real coil. So a straight piece of pipe with some current density. Is it correct that there is no analytical solution to this?
It would be enough if I had the field of a current rotating in a cylinder obviously. I am working on some Biot-Savart but either I get some ugly double roots or roots mixed with trig functions in my integrals.
Does anyone know more? I do need the off center field as well!
I can't help you with the off-center field, but there is a closed form solution for the on-axis field. It's axial (for obvious symmetry reasons) and equal to (in SI units):
[itex]B_z(z) = \frac{\mu_0 n I}{2} \left( \cos(\alpha_1) - \cos(\alpha_2)\right)[/itex]
where alpha_1, alpha_2 are the angles measured at z between the coil's axis of symmetry and the coil's upper and lower rims (assuming current starts at the bottom and circulates its way to top). n is the number of turns per unit length.
Assaf
http://www.physicallyincorrect.com"
Ozymandias' answer is a nice form of the Biot Savart equation appropriate for solenoids. It is important to note that for a long solenoid, B is independent of coil diameter. It is also useful to put some numbers in for a typical coil (μ0 = 4 pi x 10-7 Henrys per meter). using n=1000 turns carrying 10 amps, the magnetic field is 0.0126 Tesla (126 Gauss). Compare to the Earth's field (~ 1 Gauss) and the field of a neodymium-iron-boron permanent magnet (~ 1 Tesla = 10,000 Gauss).
α β γ δ ε ζ η θ ι κ λ μ ν ξ ο π ρ ς σ τ υ φ χ ψ ω
  • · Replies 43 ·
  • · Replies 26 ·
22K
