Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Time and Space Share It Thread Tools Search this Thread image
Old Jun17-09, 08:01 PM                  #1
Gear300
Gear300 is Offline:
Time and Space
Are time and space independent of an object, or are they properties of an object?
Old Jun17-09, 09:29 PM                  #2
DaleSpam
DaleSpam is Offline:
Recognitions:
Re: Time and Space
What do you mean physically. In other words, what kind of experiment could you perform to distinguish the two options?
Old Jun17-09, 09:45 PM                  #3
Civilized
Civilized is Offline:
Re: Time and Space
Statements about time and space are just statements about measurements of distance and duration, and measurements of distance and duration are reducible to observations of objects.
Old Jun17-09, 10:14 PM                  #4
Gear300
Gear300 is Offline:
Re: Time and Space
There is a space-time distortion felt by objects in motion...but is this effect felt only by the objects in motion or is this distortion extended to local space-time?
Old Jun17-09, 10:26 PM                  #5
DaleSpam
Recognitions:
Re: Time and Space
Again, what would that look like physically? How would you experimentally tell if the distortion was "felt only by the objects" or "extended to local space-time"?
The reason I ask is because if there is no experiment you can use to determine it then you are asking a philosophical question rather than a physics question. Not that there is anything wrong with philosophical questions, but just to realize that they are different from scientific questions.
Old Jun17-09, 11:05 PM                  #6
Gear300
Gear300 is Offline:
Re: Time and Space
If time is slowing down for an object traveling at high speeds, and if this is only felt by the moving object, then how would we interpret the situation: would it be that the object is distorting time (time is independent of the object), or is the object's time distorting (time is a property of the object)?
Old Jun18-09, 05:32 AM                  #7
A.T.
A.T. is Offline:
Re: Time and Space
Originally Posted by Gear300 View Post
If time is slowing down for an object traveling at high speeds, and if this is only felt by the moving object,...
You have to clearly say what you want to measure. For example: You have to identical clocks going at the same rate when placed side by side at rest to the observer. When one clock is moving relative to the observer it is measured by the observer to tick slower than the clock at rest to the observer.
You always need two clocks to define time dilation.
Does this interpretation change any measurable quantities? If not: pick the one you like more. Physics doesn't care. My favorite is that the clock advancing in space, advances less in time.
Old Jun18-09, 09:11 AM       Last edited by DaleSpam; Jun18-09 at 10:43 AM..            #8
DaleSpam
Recognitions:
Re: Time and Space
Hi Gear300, let me try and guess what I think you are asking and propose an experiment to measure it. If that is not what you are asking then maybe you can refine or correct the experiment:
Consider 3 identical ideal clocks: the reference clock, the rest clock, and the moving clock. The reference clock and the rest clock are far away from each other, at rest wrt each other, and synchronized via the standard Einstein synchronization procedure. The moving clock is moving inertially at relativistic speeds and passes the rest clock as close as possible without colliding (never coming close to the reference clock). After the moving clock departs, are the rest clock and the reference clock still synchronized?
Is that what you were getting at? If not, can you propose a different experiment?
Old Jun18-09, 11:03 AM                  #9
diazona
diazona is Offline:
Re: Time and Space
Nice post DaleSpam
Old Jun18-09, 11:47 AM                  #10
atyy
atyy is Offline:
Re: Time and Space
In special relativity, you can move objects around without changing the properties of spacetime (metric). So different positions of objects correspond to the same spacetime.
In general relativity, different positions of objects correspond to different spacetimes.
In both cases, the properties of spacetime are inferred by using objects.
Old Jun18-09, 01:05 PM                  #11
Gear300
Gear300 is Offline:
Re: Time and Space
Yes...you have it more or less on the spot...but, based on the other posts, I'm assuming this is left to little more than interpretation?
Old Jun18-09, 01:23 PM                  #12
diazona
diazona is Offline:
Re: Time and Space
In the experiment DaleSpam came up with, special relativity predicts that the rest clock and the reference clock would still be synchronized after the moving clock departs.
That entails ignoring gravity, of course, since special relativity doesn't deal with gravity. If you take into account the gravitational forces that the clocks exert on each other, then general relativity predicts that the rest clock and the reference clock would not quite be synchronized. The rest clock would be slightly behind the reference clock due to gravitational time dilation. But that would occur even if the moving clock were sitting still - it's due to the moving clock's mass, not its motion.
Old Jun18-09, 01:33 PM                  #13
DaleSpam
Recognitions:
Re: Time and Space
Relativity makes definite predictions about this experiment, how you choose to interpret the prediction is up to you. Provided there is no significant gravitation, the rest clock and the reference clock remain synchronized. If the moving clock is attached to a gravitating mass then the clocks will not remain synchronized.
EDIT: I see that diazona was quicker
Old Jun18-09, 02:07 PM                  #14
Gear300
Gear300 is Offline:
Re: Time and Space
I see...Thanks for the replies.
image image
Reply
Thread Tools
Similar Threads for: Time and Space
Thread Thread Starter Forum Replies Last Post
is space-time flat or curved over time? Gill tunnel Cosmology 2 Mar10-09 01:16 AM
motion in space due to space-time curvature cosmogrl Special & General Relativity 13 Nov3-08 01:01 PM
is time, inside an event horizon, time-like or space-like? tiny-tim Special & General Relativity 34 Apr28-08 07:42 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
