How do TOKAMAK's provide thermal insulation
  • Context: Graduate
  • Thread starter Thread starter Ian_Brooks
    Insulation Thermal
TOKAMAKs utilize magnetic fields to contain plasma at temperatures exceeding 100 million degrees Celsius without causing thermal damage to reactor materials. The plasma's unique behavior, influenced by charged particles moving in circular trajectories around magnetic field lines, allows for effective thermal insulation. Current research focuses on developing materials capable of withstanding energetic neutron collisions while maintaining low energy leakage to the confinement chamber. Additionally, energy is radiated through mechanisms such as cyclotron radiation and bremsstrahlung, necessitating cooling of the first wall.
  • Understanding of magnetic confinement in fusion reactors
  • Knowledge of plasma physics and thermodynamics
  • Familiarity with materials science related to high-energy environments
  • Basic principles of radiation, including cyclotron radiation and bremsstrahlung
  • Research advanced materials for fusion reactors capable of withstanding neutron bombardment
  • Study the principles of magnetic confinement in fusion technology
  • Explore the mechanisms of energy radiation in plasmas, focusing on cyclotron radiation
  • Investigate cooling techniques for the first wall in fusion reactors
Fusion researchers, materials scientists, and engineers involved in the development and optimization of fusion reactor technologies.
Ian_Brooks
For current fusion technology the method for containing the plasma is with magnetic fields. However the plasma reaches temperatures of 100,000 degrees+ that would melt anything on Earth -
so how do these super concentrated magnetic field provide thermal insulation?
The plasma reaching such high temperatures is really just because of our macroscopic definition of temperature. A 100 million degree tokamak plasma isn't going to melt stuff the same way a 100 million degree lump of normal material would, it just means that very energetic neutrons will occasionally hit the walls of the reactor. Making a material that can stand such collisions for a long period of time is currently an active area of research.
Charged particles move in small circular trajectories around magnetic field lines when their velocities are perpendicular to the magnetic fields. The magnetic fields are imposed on the outside of the plasma, and the plasma excludes the magnetic fields by virtue of the rotating particles producing magnetic fields opposite the fields which cause them to rotate. Therefore the magentic field is lower and the particles (ions and electrons) tend to preferentially move to the interior. Neutral atoms do pass through magnetic fields, but their flux is kept as low as possible.
The plasmas has very low density ~ 1014 ions-electrons/cm3, as compared to solid materials with atomic densities on the order of 1022/cm3. The energy leaking to the confinement chamber is very low.
Energy is also radiated in the form of photons via cyclotron radiation, recombination, and bremsstrahlung, so the first wall needs to be cooled.
16K
