Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > General Math
Reply
image Functional Equation? Share It Thread Tools Search this Thread image
Old Jun18-09, 06:45 AM                  #1
muzialis
muzialis is Offline:
Hi All,
I am asked to produce a function such that, literally, increasing the indipendent variable by lambda will produce an increase in the function of a*lambda.
I thought about setting up an equation as follows
y(lambda*x)=a*lambda*y(x)
In general a simple solution of the functional equation y(ax)-by(x)=0 is y = Kx^(ln(a)/ln(b)). C is arbitrary
Using this solution scheme I am unable to obtain solutions independent upon lambda.
Is the task well posed at all?
Thank you very much
Muzialis
Old Jun18-09, 11:22 AM                  #2
EnumaElish
EnumaElish's Avatar
EnumaElish is Offline:
Recognitions:
Homework Helper Homework Helper
Re: Functional Equation?
I would have formulated it as:
Find y such that y(x + λ) = y(x) + aλ.
Old Jun18-09, 12:43 PM                  #3
muzialis
EnumaElish,
thanks for the hint.
Your set up is coherent with my description.
However I have been imprecise, the increase is specified in the task as a multiplicative factor, so my set up is the one actually that needs solving.
I am pretty sure the task was badly posed though as I do not see how a solution could exist.
But then, that is why I posted the issue.
Thanks and all the best
Muzialis
Old Jun18-09, 01:16 PM                  #4
EnumaElish
EnumaElish's Avatar
Recognitions:
Could it mean y((1+λ)x) = (1+aλ)y(x)?
With y(λx) = aλy(x), assume (trivially) λ = 1. Then y(x) = ay(x), which is a contradiction except for a = 1. In this formulation λ has to be > 1.
Old Jun18-09, 01:44 PM                  #5
muzialis
EnumaElish,
I appreciate your ad absurdum reasoning. But can you find any solution for lambda > 1?
I am sure the task was badly posed. The fact is it was proposed to me by a working partner whose maths is usually very precise, so I wanted to be extra sure I was not stating nonsense.
It has been later clarified that all it was needed was a function with a derivative of lambda, locally in a point of interest.
I am curious now tough, if the set up I originally proposed has any solution at all, although I fear not.
Thank you very much
Best Regards
Muzialis
image image
Reply
Thread Tools
Similar Threads for: Functional Equation?
Thread Thread Starter Forum Replies Last Post
Functional Equation ritwik06 Calculus & Beyond 3 Apr29-09 11:52 PM
functional equation zetafunction General Math 1 Apr12-09 05:43 PM
functional equation f(x)=f(x^2) cliowa Calculus & Beyond 3 Jan15-06 01:29 AM
functional equation... eljose Calculus & Analysis 1 Aug21-05 07:13 AM
Functional equation spacetime Introductory Physics 1 Feb7-05 10:17 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
