Force on a Permanent Magnet Falling through a Coil
The discussion revolves around the drag force experienced by a permanent magnet falling through a coil, comparing it to a magnet falling through a conductive pipe. Participants explore the conditions under which the coil generates drag force and its implications for power production.
  • Experimental/applied
  • One participant questions the drag force on a magnet falling through a coil and whether the coil needs to be connected to a circuit to create this force.
  • Another participant asserts that the coil must be shorted for it to have an effect, suggesting that otherwise, the results may not differ significantly from those in a conductive pipe.
  • A later reply elaborates that a shorted coil allows for the formation of generator currents, contrasting with the eddy currents that form in a conductive pipe.
  • One participant shares insights from lab testing, indicating that a magnet falling through a conductive pipe produces significant drag due to eddy currents, while the drag force through a coil is likely negligible.
  • The same participant inquires whether shortening the coil would lower the drag force and discusses the balance between drag force and power production, questioning if a longer coil would be more beneficial for their project.
Participants express differing views on the necessity of shorting the coil and the resulting drag force, indicating that multiple competing perspectives remain regarding the behavior of the magnet in the coil versus the pipe.
The discussion includes assumptions about the behavior of eddy currents and generator currents in different configurations, as well as the implications of coil length on drag force and power production, which remain unresolved.
This discussion may be of interest to those exploring electromagnetic induction, drag forces in conductive materials, and applications in power generation systems.
BryanFantana
What is the drag force on a magnet falling through a coil? I have found several sources online describing the drag force on a magnet falling through a conductive pipe. How might this vary if a coil is used in place of a pipe? Does the coil need to be connected to a circuit to create this force?
The coil needs to be shorted for it to have an effect otherwise I don't think that the results differ that much.
I think this is pretty much correct. The magnet would like to induce eddy currents, and a large piece of metal allows currents to form in loops. This is why transformer, and motor cores are often laminated to reduce eddy currents. However, an open coil structure does not allow very big circular loops to form, and sort of acts like a laminated piece of metal, only better. Once, the coil is shorted, you have a very nice low-resistance loop! Perhaps, in this case, you would refer to the currents as generator currents, rather than eddy currents, since you now have a simple linear generator.
Thanks guys. From doing a little bit of lab testing and pondering, I gather that dropping a magnet down a conductive pipe produces lots of drag due to the Eddy currents forming inside the pipe. The same magnet falling down a coil experiences little drag and the drag force is probably negligible.
You guys mention shortening the coil. Would that lower the force? Ultimately the goal of my project is power production. I am trying to model how this thing might behave and I was curious about a magnetically-induced drag force. But since the force seems tiny and more power is the primary objective, would a longer coil be better?
  • · Replies 27 ·
