Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > Special & General Relativity
Reply
image Special relativity Share It Thread Tools Search this Thread image
Old Jun20-09, 12:06 AM                  #1
Urmi Roy
Urmi Roy is Offline:
Special relativity
Hi,
I've been doing the very basics of special relativity lately,and there seem to be some points that most people I know don't really understand or know for certain.As a result I've been completely confused about them,and I could really do with some expert help on them.
Firstly, in my book it says that all the results of special relativity ultimately owe their existance to the relativity of simultaneity.However, thinking about the famous train platform thought experiment I can't get down to explaining time dilation with it.
Also,in the muon experiment(which everyone must be knowing,so I won't describe it),I see the muon's clock to be running slow,so I see it living longer than it should (in my frame of reference).
But the strange thing is that the muon actually doesn't have a clock (which I can observe) to help me detect its slowly running time!!!
So how do I know (without the muon actually having any clock on it) that its time is really running slow????
The fact is that anyone--even one who doesn't have any knowlege of special relativity whatsoever sees this pheomeon occur and can easily see that the muons survive longer than they should,if allowed to.
Please help me out in this.
Old Jun20-09, 01:05 AM                  #2
superkan619
superkan619 is Offline:
Re: Special relativity
Muon expt
The clock on muon runs slower when you see it through your F.O.R. This means(and will always mean) that every process of muon that proceeds in time slows down. The decaying of muon is one such process and hence it slows down i.e half life dilates/increases and more such particles are detected.
If you consider a biological cell, time taken to complete the cell cyle increases. If you consider a television, the time taken for a programme increases (say 30 min to 30.2 min).
Note that their clock slows down but you notice it.
Old Jun20-09, 01:05 AM                  #3
sylas
sylas's Avatar
sylas is Offline:
Recognitions:
PF Contributor PF Contributor
You "know" it the same way you "know" anything in science. Science develops and tests models to describe what we observe occurring in the natural world. The specifics of how time passes at different velocities is thoroughly tested by all kinds of different experiments and observations, and as a result we have the equations of relativity to describe what occurs. A clock is anything that measures time. This includes atomic clocks which test relativity by being flown around the world on airliners, or muons that have a certain time linked decay rate.
You can't "know" it as an absolute truth. But in so far as we know anything in science, time passes more slowly at high speed, and muons and everything else we've been able to test behaves as described with this model.
Cheers -- sylas
Old Jun20-09, 01:18 AM                  #4
Urmi Roy
From what you people said, it seems easy enough, but special relativity itself is so strange and amazing that it takes a while to get used to it.
I was just thinking that perhaps in nature we always see the speed of light as 'c' so the light which is being emitted by the muon can also reach us at a constant rate only; and so it informs us of the muon's journey at that fixed rate.
Since the muon is travelling towards me its light should (by common sense)come toward me at velocity 'c+ v' (v is velocity of muon) but since the light cannot in reality move at this speed, it moves the distance (c+v)*(ideal lifetime of muon which is 2 micro seconds) at its own speed.This obviously takes more than 2 microseconds and so,by the time light does reach us, we find its duration of travel more han 2 micro seconds -----which is time dilation.
This must sound really crazy, but,as I said, it takes a while to get used to these bizarre consequences of relativity.
Another big problem is that with this dispute between what is true and what isn't , it really isn't clear whether one twin in the twin paradox does really grow older than the other-or whether this effect lasts only during the eperiment itself.
Please do send in some help!
Old Jun20-09, 02:32 AM                  #5
sylas
sylas's Avatar
sylas is Offline:
Recognitions:
That's for sure. But stick with it.
The muon experiment has nothing to do with light; it is purely about the time that muons exist. Muons are unstable and they exist for only a very short time. The time is well known, and it is much much longer than it takes for muons to get to the surface of the Earth from where they are formed by cosmic rays in the atmosphere. But because they travel so close to the speed of light, time passes more slowly for them, which they can reach the surface. Measures of number of muons and cosmic rays are -- like every other experiment trying to test this theory -- explained by the change the rate at which time passes with velocity.
It's a problem for a student to learn; and I appreciate that. It is also counter intuitive, in the sense that it doesn't fit the intuitions we form from our own experience of small velocities. But the theory itself is crystal clear in its own right. You just have to learn it; and that takes time. We can answer questions, but ultimately you will need to do a bit of study yourself and read up more on the theory. When you get to the point of being able to apply the theory for yourself to a given problem, you have a change of it starting to make more sense to you. As far as special relativity goes, this is actually not very difficult, in a technical sense.
Cheers -- sylas
Old Jun20-09, 04:32 AM                  #6
superkan619
This paradoxical experiment is not under the regime of special theory of relativity because. When one twin starts her journey from rest she is infact accelerating. Again when she tries to turn to meet her sister again shen changes her velocity changes and she accelerates. SR works only for inertial i.e non-accelerating frames.
It requires general theory of relativity which involves so much complications that mathematical physicists haven't found time to solve this paradox.
But its for sure that another Einstein will change the scene as it appears now.
Old Jun20-09, 04:38 AM                  #7
sylas
sylas's Avatar
sylas is Offline:
Recognitions:
Incorrect, in all respects.
Special relativity handles acceleration just fine, and the twin "paradox" is easily and simply solved using special relativity alone. It was NEVER a "paradox", merely an interesting consequence of special relativity that trips up people thinking in terms of mistaken intuitions only, without actually using the straightforward calculation.
Where you need the general theory is not with acceleration, but with gravity. In fact, the general theory is derived by using an equivalence of gravity with acceleration under special relativity.
Also, general relativity is more complicated to be sure; but it is not so complicated that it takes up any particular amount of extra time once you've put in the time to learn it.
Cheers -- sylas
Old Jun20-09, 07:19 AM                  #8
Urmi Roy
Thanks for you expert help.
I'll be looking forward to further assistance in the near future.
Sorry if my questions are a bit dumb,since I've only just passed high school and I just did a bit of extra reading on special relativity before getting into engineering college.
Old Jun20-09, 10:07 AM                  #9
superkan619
Me too the same thing......
Old Jun20-09, 10:14 AM                  #10
superkan619
I wish I could have referenced this statement in my reserach paper.
Old Jun20-09, 10:41 AM                  #11
superkan619
Thank you sylas, p'haps you are mathematical buddy well equipped with Tensor calculus. I haven't yet started my course in vector calculus. By "extra time" I don't mean solving some tensorical equations, but thinking out of GR. To remove its absoluteness of S-T, energy anomaly, to completely (and physically) formulate and prove the General Principle of relativity(key to twin paradox).
So far as the twin paradox is concerned, dozens say they have solved it but no one has been able to put away with the unusual consequence that preferential F.O.R do exist.
No inertial frame is naturally more preferred in SR.
No frame of any kind is naturally more preferred.(GenPrinRel)------>here arises the problem.
Old Jun20-09, 11:02 AM                  #12
Naty1
Naty1 is Offline:
Recognitions:
This idea "strange and amazing" applies to a lot of science...the more you learn the stranger science gets. Keep that in mind!!!!! Time, space and energy are not absolutes..they depend on your frame of reference. Even "worse" everything is "uncertain" no matter how perfect our instruments....even the hardest,toughest metal is 99.99999% "empty space"....
And if you get to quantum mechanics things get even crazier, meaning not intuitive, not consistent with our everyday senses.
Richard Feynman once said something close to "Nobody understands quantum mechanics" and may have also authored "shut up and compute" (I think) meaning that we could argue forever about what the math means, but we can all agree on the correct computations...
Old Jun20-09, 11:36 AM                  #13
DaleSpam
DaleSpam is Offline:
Recognitions:
It does have an observable clock: its decay time. It is not a terribly accurate clock for a single muon, but take a few million muons and the half-life is well known to high precision.
Old Jun20-09, 11:59 AM                  #14
Janus
PF Mentor
Janus's Avatar
Janus is Offline:
All that is needed to "resolve" the Twin Paradox without the introduction of a preferential F.O.R. is an understanding and application of:
1. Time dilation
2. Length contraction
3. The Relativity of Simultaneity
Old Jun20-09, 12:29 PM       Last edited by sylas; Jun20-09 at 12:50 PM..            #15
sylas
sylas's Avatar
sylas is Offline:
Recognitions:
There's no problem, except for the difficulty of any individual as they learn new ideas. The maths and concepts may be counter intuitive at first, but is not complicated or difficult or paradoxical. There is no preferred frame of reference; you can use any inertial frame you like and get precisely the same result for ages of the twins. Only one twin is an inertial frame of reference themselves, of course. The other isn't. You can use special relativity to calculate all the observations and consequences for an accelerated frame as well, but this generally involves picking an inertial frame (any frame will do, none is preferred) to calculate observations and proper time for the twin that is not inertial. Obviously, you don't do it by thinking they are equivalent to an inertial frame, and if you think there is a preferred frame, then you simply don't understand the maths yet.
That can be fixed... as long as you have the elementary common sense to recognize that perhaps you might NEED to learn something about it before making grand pronouncements.
Cheers -- sylas
PS. I am not good with tensors or GR myself. But I do know SR. And in my opinion, the best first step is simply the Lorentz transformation. "Time dilation" and relativity of simultaneity and all the rest are consequences, but you are better to use the Lorentz transformations directly.
PPS. My apologies if I am stating what you already know. Your comments are not entirely clear to me. When you say "no one has been able to" do whatever it is you think they should do, this makes no sense. You can use GR to describe the accelerated frame if you like, but this is overkill for the problem.
Old Jun20-09, 01:35 PM       Last edited by superkan619; Jun20-09 at 02:06 PM..            #16
superkan619
Thumbs up Re: Special relativity
"I often say that when you can measure something and express it in numbers, you know something about it. When you cannot measure it, when you cannot express it in numbers, your knowledge is of a meager and unsatisfactory kind. It may be the
beginning of knowledge, but you have scarcely in your thoughts advanced to the stage of science, whatever it may be."--Lord Kelvin
I accept of my faulty remarks about preferential F.O.Rs.
For two twins, one accelerating without giving the other some acceleration is impossible. The acceleration is not even a small one in magnitude to be approximated.
Thats the clear reason why I supposed it to be out of SR(although GR depends on SR). Frankly, now I myself is imposed upon a question that if there were three twins, so that the third's acceleration cancels the acceleration of the observer twin, then what might happen???
There is truely something that is forcing me (since 2 yrs) to enquire about what may be called the 4th point in Mr. Janus' list.
I realise it (humbly!) that u guys are tougher than me, really. I've just finished my high school where even S relativity hasn't been taught to us. So, my experiences with SR and GR are more physical than mathematical. Thankx to PF, I am going to refer a more detailed book on it. Please accept me as a kid enquiring about what he loves. I just wanted to expose some of my thinkings(may be childish) to you guys. The concept of Cartesian space(PS Don't confuse it with any geometry i.e Euclidean or Reimmanian; also not with an empty set of axes) is one such thing which some of you might be thinking of as a grand pronouncement for you. Thats not the spirit of physics. Forgive the superkan.
Do not go where the path may lead, go instead where there is no path and
leave a trail.-----Ralph Waldo Emerson
image image
Reply
Thread Tools
Similar Threads for: Special relativity
Thread Thread Starter Forum Replies Last Post
How much is Special Relativity a needed foundation of General Relativity lalbatros Special & General Relativity 74 Nov10-09 12:18 PM
Very special relativity? Schrodinger's Dog Special & General Relativity 22 Feb5-07 06:44 PM
Special Relativity vs. General Relativity IndustriaL Special & General Relativity 25 Jun14-05 03:05 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
