Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > Calculus & Analysis
Reply
image holomorphic=analytic? Share It Thread Tools Search this Thread image
Old Jun20-09, 01:09 PM       Last edited by lolgarithms; Jun20-09 at 01:15 PM..            #1
lolgarithms
lolgarithms is Offline:
Is a complex function complex diffferentiable if AND only if they are analytic? or are there counterexamples?(analytic functions which are not holomorphic)
Why do you need to sometimes analyticially continue an analytic function?
Old Jun20-09, 01:19 PM                  #2
Civilized
Civilized is Offline:
Re: holomorphic=analytic?
That's right, this is one of the beautiful things which occurs in complex analysis.
In a higher dimensional complex space, the holomorphic functions are a proper subset of the analytic ones, but in the complex plane the two classes of functions coincide, this is a major theorem in complex analysis.
If the analytic function is defined not on the whole of the complex plane but only on an open subset.
Old Jun20-09, 01:23 PM       Last edited by zpconn; Jun20-09 at 01:31 PM..            #3
zpconn
zpconn is Offline:
All analytic functions (real and complex) are infinitely differentiable. Thus any complex analytic function is complex differentiable, so it is holomorphic.
It's actually the converse that is interesting in complex analysis. Any function that is holomorphic is also analytic. Of course I'm speaking loosely here; consult a text on complex analysis to see precise statements of these results.
This is in stark contrast to the case in real analysis. For example, try to differentiate
f(x) = { 0 if x <= 0; x^2 if x >= 0 }
twice.
In fact, what's even more remarkable is that we can explicitly calculate all the derivatives of a holomorphic function. For example, if LaTeX Code: f : C \\rightarrow C is differentiable near LaTeX Code: x_0 , then it is infinitely differentiable at LaTeX Code: x_0 , and
LaTeX Code: <BR>f^{(n)}(x_0) = \\frac{n!}{2\\pi i} \\int_{C} \\frac{f(z)}{(z - x_0)^{n+1}}dz<BR>
where LaTeX Code: C is just a sufficiently small loop surrounding LaTeX Code: x_0 . Using this, one can explicitly compute the coefficients in the power series representation of a holomorphic function.
Old Jun20-09, 01:28 PM                  #4
Civilized
In the real numbers we can even have functions that are infinitely many times differentiable at a point that are still not analytic at that point e.g.
f(x) = {0 if x < 0 ; exp(-1/x^2) x > 0}
all the derivatives exist at x = 0, but they are all zero so the power series at that point is f(x) = 0 + 0 + 0 + ... which has zero radius of convergence and so the function is not analytic at that point.
Old Jun20-09, 01:59 PM       Last edited by lolgarithms; Jun20-09 at 02:05 PM..            #5
lolgarithms
please give me an example of where analytic continuation is needed, and the power series for the analytically continued function.
Old Jun20-09, 02:46 PM                  #6
zpconn
zpconn is Offline:
Consider LaTeX Code: f(x) = 1/(1+x^2) where x is real. If one writes
LaTeX Code: <BR>f(x) = \\sum_{j=0}^{\\infty} c_j X^j<BR>
where LaTeX Code: X = x - k is the distance from x to some center k, then one can show that the radius of convergence is
LaTeX Code: <BR>\\sqrt{1 + k^2}.<BR>
If we choose LaTeX Code: k = 0 , for example, the radius of convergence is mysteriously 1, yet if one examines the graph of f one will not see anything wrong at x = 1 or x = -1.
In fact, this is when it is useful to consider the complex function LaTeX Code: F(z) = 1/(1+z^2) . Of course F(z) agrees with f(x) when z is restricted to the real line. Now note that the quantity
LaTeX Code: <BR>\\sqrt{1+k^2}<BR>
is the distance in the complex plane from the center k to the points LaTeX Code: i and LaTeX Code: -i . Of course, these points LaTeX Code: i, -i are singularities of the complex function F(z) but not of the real function f(x), so we see that the radius of convergence of f(x) is the distance to the nearest singularity of the complex function F(z); in fact, although I won't explain it now, this is true generally if one replaces "nearest singularity" with "nearest singularity or branch point."
In this case I've "went backwards." Clearly F(z) is defined everywhere except at z = i and z = -i. So if one has a series representation of F(z) as above, then F(z) would be the analytic continuation of this series to the entire plane (except z = i and z = -i).
Here's a slightly better example. Consider the function
LaTeX Code: <BR>h(z) = 1 + z + z^2 + \\dots<BR>
This converges within the unit disc LaTeX Code: |z| < 1 and consequently is analytic there. Except for a singularity at z = 1, this function can be analytically continued to the whole plane as
LaTeX Code: <BR>H(z) = \\frac{1}{1-z}.<BR>
You can check that h and H agree within the unit disc. Further, this continuation is unique.
A very loose and rough way of thinking about this is as follows. If an analytic mapping sends any arbitrarily small curve to a point, then the mapping will send its entire domain to that point. Thus if LaTeX Code: H_1 and LaTeX Code: H_2 were two distinct continuations of LaTeX Code: h , then the function LaTeX Code: H_1 - H_2 would send the unit disc to the origin and thus LaTeX Code: H_1 - H_2 = 0 .
Old Jun25-09, 10:43 AM       Last edited by g_edgar; Jun26-09 at 08:54 AM..            #7
g_edgar
g_edgar is Offline:
Is a complex function complex differentiable if AND only if they are analytic?
On an open set, yes. At a single point, no.
image image
Reply
Tags
analytic, complex analysis, holomorphic
Thread Tools
Similar Threads for: holomorphic=analytic?
Thread Thread Starter Forum Replies Last Post
Holomorphic functions Niles Calculus & Beyond 1 Jun8-09 01:04 PM
Holomorphic latentcorpse Calculus & Beyond 5 Mar20-09 03:28 AM
holomorphic convexity lark Calculus & Analysis 0 Dec2-08 11:45 AM
holomorphic map Ant farm Calculus & Analysis 7 May12-07 04:36 PM
holomorphic at infinity quasar987 Calculus & Analysis 6 Apr14-06 08:34 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
