e(ho0n3 said:
I'm really confused now. You say I can use Newton's laws in an accelerated reference frame but from what I've learned (particularly from my book), Newton's laws are invalid in such frames. So which is right here?
Let's make a careful examination of the concept of "accelerated reference frame" and inertial reference frame.
Suppose we have an inertial frame I and an object O, whose acceleration in I satisfies Newton's 2.law:
[tex]F=ma_{I}[/tex]
I have put the subscript I to signify that this is the acceleration of O as measured in I.
Now, let us first consider a reference frame I' whose origin moves with velocity [tex]v_{0'}[/tex] as measured in I (axes in I' remains parallell to axes in I).
Let us first consider the case where an observer in I measures
[tex]v_{0'}[/tex] to be a constant in time.
Now, by the Galilean transformation of velocities, the velocity of object O as measured in I' is related to object O's velocity as measured in I by:
[tex]v_{I'}=v_{I}-v_{0'}[/tex]
We want now to find the acceleration of O as measured in I':
[tex]a_{I'}=\frac{dv_{I'}}{dt}=\frac{dv_{I}}{dt}-\frac{dv_{0'}}{dt}[/tex]
But [tex]v_{0'}[/tex] was constant in time; hence we have:
[tex]a_{I'}=a_{I}[/tex]
That is, an observer in I' measures O's acceleration to be the same value as the one an observer in I gets!
But, therefore, we gain:
[tex]F=ma_{I'}[/tex]
That is, Newton's 2.law is valid even though we look at O from I' rather than from I
Hence, I' is also an inertial frame.
Now, let's take the case with a reference frame I'', whose origin's velocity is meaused as non-constant in I (axes still parallell, for simplicity)
Doing the same computations, we get:
[tex]a_{I''}=a_{I}-a_{0''}[/tex]
Substituting for [tex]a_{I}[/tex] in Newton's 2.law and rearranging, we get:
[tex]F-ma_{0''}=ma_{I''}[/tex]
That is, the set of forces an observer in I'' can glimpse from measuring O's acceleration is not the same set of forces that an observer in I measures!
For an observer in I'' it seems there is a new force present (we call it a fictitious force) which is equal to [tex]-ma_{0''}[/tex]
This is what is meant by using Newton's 2.law in an accelerated frame of reference:
To add the requisite fictitious forces to the left-hand side of the equation.
(Often, this simplifies problems)
