Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > General Math
Reply
image Impossible equation to solve? Share It Thread Tools Search this Thread image
Old Jun26-09, 02:41 AM                  #1
Jiachao
Jiachao is Offline:
Hi, I know its possible to get an answer by graphing the curves and finding the point of intersection but I was wondering if there was a way to do them algebraically.
sin(2x) = LaTeX Code: \\frac{x}{2}
or LaTeX Code: e^{\\frac{x}{8}} = x
Also, do these types of equations have a name?
Old Jun26-09, 03:03 AM       Last edited by Nabeshin; Jun26-09 at 03:11 AM..            #2
Nabeshin
Nabeshin's Avatar
Nabeshin is Online:
Recognitions:
PF Contributor PF Contributor
Re: Impossible equation to solve?
Your first equation is not solvable (in terms of elementary functions or any I know of). The equation simply is not written in a way in which it is possible to express it as a solution x=something.
The second equation at first glance appears the same, but is actually solvable (although not in terms of elementary functions). The solution is:
x=-8 W(-1/8)
Where W is the Lambert W function. ( http://en.wikipedia.org/wiki/Lambert%27s_W_function )
I don't know of a name for these [unsolvable] equations, I'd call em non-algebraic (not sure if that's official though).
Old Jun26-09, 03:57 AM                  #3
arildno
arildno is Offline:
Recognitions:
Homework Helper Homework Helper
They are called transcendental equations.
Old Jun26-09, 04:19 AM                  #4
Jiachao
Jiachao is Offline:
Thanks for the replies.
Old Jun26-09, 01:20 PM                  #5
camilus
camilus is Offline:
haha try this one. Let me know if you're interested in the problem, I actually got it from physicsforums.com.
LaTeX Code: \\left [{1 \\over 2}\\sqrt{1 - n^2x^2} + {\\arcsin (nx) \\over 2n} \\right ]_{0}^{6} = e + \\pi
n=?
Old Jun26-09, 03:09 PM                  #6
Дьявол
Дьявол is Offline:
And what are the 0 and 6 ??
Old Jun26-09, 03:36 PM                  #7
HallsofIvy
PF Mentor
HallsofIvy is Offline:
I assume that he means that formula evaluated between 6 and 0: its value at 6 minus its value at 0 is equal to LaTeX Code: e+ \\pi .
Old Jun26-09, 06:18 PM                  #8
camilus
camilus is Offline:
of course. Its an integral remember?
LaTeX Code:  \\int_0^{6}\\sqrt{1 - (nx)^2}dx = e + \\pi
Old Jun26-09, 10:45 PM                  #9
Jiachao
Jiachao is Offline:
I'm still in high school so is that possible to solve using my level of mathematics?
After I subbed the numbers in, I did a quick sketch on graphmatica and it didn't show any intersections between
LaTeX Code:  y = \\sqrt{1-36n^{2}}  +\\frac{arcsin (6n)}{n} -1
and y = 2e + 2pi
so have I done something wrong already?
Old Jun27-09, 07:45 AM                  #10
g_edgar
g_edgar is Offline:
I agree that there is no solution to
However, there is a solution to
LaTeX Code:  \\int_0^{6}\\sqrt{1 - (nx)^2}\\,dx = e + \\pi
camilus is mistaken in asserting that these are equal.
Old Jun27-09, 09:27 AM                  #11
ulquiorra
ulquiorra is Offline:
The equations in the first post can't be solved explicitly for x, but you could use a method of iteration to get as accurate a solution for x as you require.
Old Jun27-09, 05:48 PM                  #12
camilus
camilus is Offline:
LaTeX Code:  \\int_0^{6}\\sqrt{1 - (nx)^2}\\dx = e + \\pi
wtf? explain..?
LaTeX Code:  \\int_0^{6}\\sqrt{1 - (nx)^2}\\dx = \\left [{1 \\over 2}\\sqrt{1 - n^2x^2} + {\\arcsin (nx) \\over 2n} \\right ]_{0}^{6} = e + \\pi
now you gotta find what value of n will make will make the integral equal to e + pi. I have found n to several digits, although Im under the impression that n is nonalgebraic.
Old Jun27-09, 11:14 PM                  #13
Mentallic
Mentallic is Offline:
Originally Posted by camilus
wtf? explain..?
LaTeX Code: \\int_0^{6}\\sqrt{1 - (nx)^2}\\dx \\neq \\left [{1 \\over 2}\\sqrt{1 - n^2x^2} + {\\arcsin (nx) \\over 2n} \\right ]_{0}^{6}
Now, I can't actually explain because I don't know how to evaluate the integral, but I did go about it backwards and derived the result. They're not equal from what I can see.
Old Jun28-09, 08:19 AM                  #14
g_edgar
g_edgar is Offline:
the integral should be
LaTeX Code: <BR>\\int \\sqrt{1-(nx)^2}\\,dx =\\frac{1}{2}\\;x\\;\\sqrt{1-(nx)^2} +<BR>\\frac{1}{2n}\\;\\arcsin({nx)<BR>
notice the extra LaTeX Code: x ?
Old Jun28-09, 08:39 AM       Last edited by uart; Jun28-09 at 08:56 AM..            #15
uart
uart is Offline:
It is relatively easy to show that:
LaTeX Code: \\int \\sqrt{1 - (nx)^2}\\, dx = {1 \\over 2} x \\sqrt{1 - n^2x^2} + {\\arcsin (nx) \\over 2n}
Two methods come to mind.
Method 1.
Substitute LaTeX Code: nx = \\sin(u) and it transforms into LaTeX Code: 1/n \\int \\cos^2(u) du . Then just use the trig identity cos^2(u) = 1/2 + 1/2 * cos(2u) and it's straight forward to get the above stated result.
Method 2. (A little more complicated but avoids need for trig identities and "trig of inverse trig" simplifications).
Note that LaTeX Code: \\sqrt{1-(nx)^2} = 1/ \\sqrt{1-(nx)^2} \\, - \\, (nx)^2 / \\sqrt{1-(nx)^2}  . The first term is pretty much a standard inverse sin integral and the second term is amenable to integration by parts. This is actually one of those integration by part problems where you end up with the original integral on both the left and right hand side of the equals sign and it simplifies down pretty easily (again to give the above stated result).
Edit. Yes thanks g_edgar. I didn't notice that missing x before.
Old Jun28-09, 09:05 AM                  #16
Mentallic
No uart, you are wrong here. g_edgar posted the correct integral and I was able to confirm it for myself by again differentiating the result.
Originally Posted by uart View Post
It is relatively easy to show that:...
Funny how it can be relatively easy to show the wrong answer
image image
Reply
Thread Tools
Similar Threads for: Impossible equation to solve?
Thread Thread Starter Forum Replies Last Post
solve the equation nameVoid Precalculus Mathematics 3 Apr17-09 01:04 PM
help me to solve this equation sahar1978 Precalculus Mathematics 2 Feb1-09 03:32 PM
How to solve this equation... sammyb787 Calculus & Beyond 1 Sep18-07 10:20 PM
Solve this equation Mica Differential Equations 4 May18-06 10:16 AM
Help me solve this equation Bad_Boy_Blue General Math 4 Oct22-04 01:41 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
