Register to reply
Force Calculation in deflecting a sheet metal part
by sree67
Tags: deflection, force, sheet metal
Share this thread:
sree67
#1
Jun26-09, 02:16 AM
P: 2
Hi
Could anyone help me in calculating the force required to deflect a sheet metal part (see attached excel file for details)
Phys.Org News Partner Science news on Phys.org
Final pieces to the circadian clock puzzle found
A spray-on light show on four wheels: Darkside Scientific
How an ancient vertebrate uses familiar tools to build a strange-looking head
Q_Goest
#2
Jun27-09, 07:24 AM
Sci Advisor
HW Helper
PF Gold
Q_Goest's Avatar
P: 2,907
Hi sree. I've attached your spreadsheet with a couple of questions. If the U portion is constrained such that it doesn't move much, and if all the bending is occuring between the dimple and the point indicated, then this is a simple beam in bending and you can use the calculation on the second tab to determine stress, load and deflection.
If those assumptions are incorrect, then you'll need to clarify how this part works.
sree67
#3
Jun28-09, 11:29 PM
P: 2
Thanks Q Goest. Appreciate your help. Your input has helped a lot.
pruthvi11
#4
Jul1-09, 07:11 AM
P: 1
hey hi .. what formula for force calculation can be used inorder to deflect a simple flat membrane provided the opposite edges are fixed.
actually i used this one .
deflection = -alpha *load per unit area* length^4/E* thickness^3
but im not getting desired results
is there any alternate formula for it ??
Register to reply
Related Discussions
The Center of Charge of a triangular, metal sheet General Physics 0
Sheet Metal Joining Mechanical Engineering 1
Need Testing and Feedback on Excel Coil Calculations Sheet (Part 2) Electrical Engineering 0
Metal Reactivity, Part II Chemistry 2
Thickness of a sheet of metal? Introductory Physics Homework 2
