| Thread Closed |
Prime number divisibility |
Share Thread | Thread Tools |
| Jun28-09, 08:29 PM | #1 |
a, b, P, and any other numbers introduced are members of the integer set. If P is known to be a prime number, and ab can be divided by P, then prove that either a or b can be divided by P. 2. Relevant equations All properties of real numbers. Need not be explicitly mentioned in the proof. 3. The attempt at a solution ab=p*c such that the complete factorization of ab results in p multiplied by the complete factorization of c. I don't know what to do from here. |
| Jun29-09, 12:49 AM | #2 |
Assume that p does not divide b (if it does then we are done). Then gcd(p,b)=1 and so there exist integers x and y such that xp + yb = 1. Multiply through by a to get the equation xpa + yba = a
| Jun29-09, 02:52 AM | #3 |
Multiplication does not introduce new factors to the product, it is just the addition of all pre-existing factors. Hence, if a*b can be divided by P, then the factor which enables this must be located in either a or b.
You probably want something a little more formal than that blurb though. k Edit: I re-read this and I don't think I was too clear, so I'll try to elaborate a little: If you have a number X consisting of the factors a and b so that X = a * b, and a number Y consisting of the factors a and c so that Y = a * c, then the multiplication of X and Y is the same as putting all the factors together. XY = aabc When you perform this process of putting all the factors together, you are not creating any new factors, just combining those you already have. For the original question, this means that if ab is divisible by P, then the factors which makes ab divisible by P must be in either a or b, no new factor occur in the multiplication of the two. Or, perhaps easier: P is a prime. ab is divisible by P, and so ab must contain P as a factor. But P is prime, so P cannot be the product of two different integers (one part in a and one part in b), because that violates the definition of a prime number. So a or b must already contain P before the multiplication. |
| Thread Closed |
| Tags |
| divisibility, prime, proof |
| Thread Tools | |
Similar Threads for: Prime number divisibility
| 8-digit number and divisibility puzzle | Brain Teasers | 3 | ||
| a prime number which equals prime numbers | General Math | 10 | ||
| Number Theory - divisibility and primes | Calculus & Beyond Homework | 1 | ||
| Prime numbers and divisibility | Linear & Abstract Algebra | 4 | ||
| A formula of prime numbers for interval (q; (q+1)^2), where q is prime number. | Linear & Abstract Algebra | 0 | ||
