Solve Logarithm Problem: Exponential Form & Single Expression
  • Thread starter Thread starter math4life
    Logarithm
The problem involves solving a logarithmic equation and rewriting a sum of logarithms as a single expression. The specific equation is Log2(2-5x)=7, and the expression to rewrite is 3log x +(1/2)log z.
  • The original poster expresses uncertainty about solving the logarithmic equation and rewriting the logarithmic expression. Some participants provide hints regarding the relationship between logarithmic and exponential forms, while others clarify logarithmic properties and rules.
Participants are actively engaging with the problem, offering hints and clarifications about logarithmic properties. There is a mix of attempts to guide the original poster without reaching a consensus on the solutions.
There is mention of different bases in the logarithmic expressions, which raises questions about how to combine them. The original poster also indicates a lack of understanding regarding the application of logarithmic rules.
math4life
1) Solve the equation using the exponential form of the equation.
Log2(2-5x)=7
2) Rewrite as a single logarithmic expression:
3log x +(1/2)log z
1) I have no idea how to solve this.
2) I know that two logarithms multiply to add, but these have different bases so I do not know what to do.
Thanks.
math4life said:
Log2(2-5x)=7
Here is a hint.
[tex]a^b =c \Rightarrow b= log_a c[/tex]
3log x +(1/2)log z
they are in the same base. Logx usually means log10x.
Use the rule
[tex]rlog_a x = log_a x^2[/tex]
I'll just fix up rock.freak667's little typo there.
What was meant to be said is: [tex]r.log_a(x)=log_a(x^r)[/tex]
Coupled with the rule that [tex]log_a(b)+log_a(c)=log_a(bc)[/tex]
You should have no problem solving the second one :smile:
I think it might be helpful to add that a logarithm can be thought of as the exponent on the base (the number raised to a power) that results in a particular number. So for example, log10100 means the exponent on 10 that results in 100. In other words, this logarithm is the answer to the question 10? = 100. Pretty clearly, the placeholder represented by ? is 2.
Every equation of the form logbx = y can be rewritten as an equivalent exponential equation by = x, and vice versa, with the only restrictions being that b > 0, and b[itex]\neq[/itex] 1, and x > 0.
  • · Replies 22 ·
