Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Thery question Share It Thread Tools Search this Thread image
Old Jun28-09, 10:59 PM                  #1
exportedhuman
exportedhuman is Offline:
Thery question
Hello,
I might sound odd, but I need to understand how you come up with a differential equation then end it up with some solution.
How sure are you that your solution is correct ?
THANK YOU
Old Jun28-09, 11:01 PM                  #2
nicksauce
nicksauce's Avatar
nicksauce is Offline:
Recognitions:
Homework Helper Homework Helper
Re: Thery question
It is easy to show that a solution to a differential equation is correct. Simply substitute your solution into the differential equation and show that it indeed solves the equation.
Old Jun28-09, 11:16 PM                  #3
exportedhuman
Re: Thery question
But how do you make up an equation ?
Old Jun28-09, 11:39 PM                  #4
Civilized
Civilized is Offline:
Re: Thery question
Start with a function, and take it's derivative e.g.
y = sqrt(x)
y' = 1/{2 sqrt(x)}
Therefore we have the differential equation:
y' = 1/{2 y}
I think it is good practice for students to do these types of exercises.
Old Jun29-09, 07:34 AM                  #5
pbandjay
pbandjay is Offline:
Re: Thery question
If you are referring to ways to formulate a differential equation from a physical application, calculus books usually give some of the easy basic examples.
If you were given two variables: x, y; and you were told that y is proportional to x, how would you come up with an equality to relate the two variables? You would probably come up with something similar to (for constant of proportion k):
LaTeX Code: y=kx
Now, suppose you are given a function y(x) and told that its rate of change is proportional to its position for every value of x. What type of equality would you find for this? Something like:
LaTeX Code: \\dfrac{dy}{dx}=ky
It's that easy in this example, all we did was find an equality that relates the function and its derivative based on our given information. Solving this ODE gives us the formula for exponential growth (or decay, for negative values of k) at time x. Perhaps a variable t would have been a better choice. Nevertheless:
LaTeX Code: \\displaystyle\\int\\frac{dy}{y}=\\displaystyle\\int kdx
LaTeX Code: \\ln(y)=kx+c
LaTeX Code: y(x)=e^ce^{kx}=y_0e^{kx}
because if we set x=0 then we have y(0)=e^c and can reassign that constant to e^c=y_0.
Perhaps later if I feel more creative and awake I can come up with a better example of formulating a differential equation. Many, many, others are certainly not this easy.
Old Jun29-09, 08:19 AM                  #6
HallsofIvy
PF Mentor
HallsofIvy is Offline:
Re: Thery question
Many differential equations from physics problems come from "force equals mass times acceleration". Acceleration is the second derivative of position so that gives a second order differential equation:
LaTeX Code: m\\frac{d^2x}{dt^2}= F(x, t)
where F(x,t) is the function giving the force on the object at each position x and time t.
In many chemistry problems you are given the rate at which chemicals combine which immediately leads to a differential equation.
But in general, HOW you derive a differential equation from a problem (or whether a differential equation relates to the problem at all) depends strongly upon the problem.
Old Jun29-09, 08:23 AM                  #7
quasar987
quasar987's Avatar
quasar987 is Offline:
Recognitions:
PF Contributor PF Contributor
Re: Thery question
There are several ways. For instance
(1) From experimental data. The derivative of a quantity Q represents the speed at which Q varies. One might measure experimentally the relation between the derivatives of various quantitie and the mathematical way to express this relation is a differential equation.
(2) From another differential equation. The wave equation is a differential equation that is obtained from Newton's 2nd law a motion (which is itself a differential equation) by making some suppositions and approximations.
But note that as with most (every?) equations of physics, the solutions are only approximations to reality, so while they are correct mathematically, they only approximate the physics (but often astonishingly well!).
image image
Reply
Thread Tools
Similar Threads for: Thery question
Thread Thread Starter Forum Replies Last Post
[SOLVED] Proof Thery Exercise cannibal Engineering, Comp Sci, & Technology 3 Mar24-08 09:14 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
