What is the Relationship Between Space and Time?
The discussion revolves around the relationship between space and time, particularly in the context of Einstein's theories and concepts such as time dilation and length contraction. Participants explore the mathematical representation of distances in space and how these concepts apply in different reference frames.
  • Homework-related
  • One participant expresses confusion regarding Einstein's implication that space and time are interconnected, seeking clarification.
  • Another participant presents a mathematical formulation for distance in three-dimensional space, discussing how this changes under different coordinate systems due to relativistic effects.
  • A participant notes that while time dilation is a known effect, it is not easily noticeable until approaching the speed of light.
  • Further clarification is provided on the meaning of the variables in the distance equation, using a 3D grid analogy to explain changes in coordinates.
  • Participants discuss the implications of relativity on measuring distances and how different observers may perceive distances differently based on their relative motion.
Participants generally agree on the basic concepts of space and time as described by relativity, but there is a lack of consensus on the clarity of the explanations provided, particularly for those new to the subject.
Some participants express uncertainty about the mathematical details and terminology used, indicating a potential gap in foundational knowledge among newer members.
This discussion may be useful for individuals interested in the foundational concepts of physics, particularly students new to the subject who are exploring the relationship between space and time.
Ygmaince241
I was reading "Black Holes and Time Warps", by Kip Thorne. I was puzzled a bit on a certain subject. Einstein implies that your space and time is a mixture of my space and time. I'm confused there. Can somebody help me out.
The distance between two points (ds) in 3 dimensional space is (dx is difference along the x axis, etc.):
[tex]ds^2 = dx^2 + dy^2 + dz^2[/tex]
(this is just the Pythagorean theorum)
If you rotate the x-axis/y-axis/z-axis or move the orgin of the particular co-ordinate system ds always has the same value.
I'm sure your at least partially famliar with the concepts of time dialtion and length contraction in special relativity, well because of length contraction if my co-ordinate system is traveling relative to another co-ordinate system ds is no longer the same in both co-ordinate systems, i.e. the two obsrevers measure diffrence distances between objects.
But if we amend our equation for ds so that:
[tex]ds^2 = dx^2 + dy^2 + dz^2 - c^2dt^2[/tex]
Once again all diffreent co-ordinate systems measure the same values for ds.
In this way a change in velcoity is analogus to a rotation of our axes, so two obsrevers might no longer have the same x-axis or 'time-axis'.
Ok, thanks for trying to explain, but I had no idea what you said.:lol: Whats a x-axis, and all the other stuff you said. I could always use a physics teacher. I am only 14, and am pretty new to physics. Yes, I do know that motion dilates time. However, we as people do not notice it, because it is only obviously noticable or effective when approaching the speed of light.
Think of x, y, and z as length, width, & height. The "d" thing just means "a change in" (like "a change in x"). Now imagine a 3D grid. That grid has length (x), width (y), and height (z). Now imagine you're at one point in the grid and jcsd is at another. If you draw a line between you and jcsd, you can describe the distance of that line as a difference in your x, y, and z coordinates.
If jcsd is 10 ft away from you at the same ground level, then dx is 10 ft. And your distance is 10 ft.
[tex]ds^2 = 10^2 + 0 + 0[/tex]
If jcsd is 10 ft away from you sitting on top of a 10 ft tall basketball net, then he's 14 ft away from you (imagine the slanted part of the triangle if you draw the horizontal, vertical, and connecting lines between you and him).
[tex]ds^2 = 10^2 + 0 + 10^2[/tex]
Then once you start inserting the effects of Relativity, things get screwy and you need that additional factor in the equation that jcsd mentioned.
Ok, thanks. I got most of that. :smile:
  • · Replies 20 ·
  • · Replies 48 ·
