Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Aleph^aleph Share It Thread Tools Search this Thread image
Old Jul4-09, 01:47 PM                  #1
Phrak
Phrak is Offline:
Recognitions:
PF Contributor PF Contributor
Aleph^aleph
A set of cardinality LaTeX Code: \\aleph_0 has elements that are sets of size LaTeX Code: \\aleph_0 , and so on.
Counting elements, I get
LaTeX Code: \\aleph_0 + \\aleph_0^2 + ... + \\aleph_0^{\\aleph_0}\\ .
Is this the same size as LaTeX Code: \\aleph_0 ?
Old Jul4-09, 02:03 PM                  #2
Hurkyl
PF Mentor
Hurkyl's Avatar
Hurkyl is Offline:
Re: Aleph^aleph
I don't know what you mean by this
What you're actually summing here isn't perfectly clear. But, at least, I can point out that LaTeX Code: \\aleph_0^{\\aleph_0} > \\aleph_0 .
Old Jul4-09, 11:46 PM                  #3
Phrak
Phrak is Offline:
Recognitions:
Re: Aleph^aleph
I'm afraid I've blundered the original question.
A set A has cardinality of c, where c is the size of the set of real numbers. |A| = c.
Br are the elements of A. The Br are sets, themselves, of cardinality c.
Cr are the elements of each of the sets Br. The Cr are sets, themselves, of cardinality c.
This continues, ad infinitum.
Counting elements the sum of the elements of every set, I get
x = c + c2 + c3 + ...
Is x equal to c or larger?
Old Jul5-09, 12:09 AM                  #4
Hurkyl
PF Mentor
Hurkyl's Avatar
Hurkyl is Offline:
Re: Aleph^aleph
Equal. Because:
LaTeX Code: x = \\sum_{n \\in \\mathbb{Z}^+} c^n<BR> = \\sum_{n \\in \\mathbb{Z}^+} c<BR> = \\aleph_0 \\cdot c = c
Old Jul5-09, 12:38 AM                  #5
Phrak
Phrak is Offline:
Recognitions:
Re: Aleph^aleph
Originally Posted by Hurkyl View Post
Equal. Because:
Thanks Hykyl. Since time I asked, I found a raft of information in wiki's Cardinality section as well.
Old Jul5-09, 07:57 AM                  #6
Preno
Preno is Offline:
Re: Aleph^aleph
No, it doesn't, because of the axiom of regularity.
Old Jul5-09, 11:20 AM                  #7
Phrak
Phrak is Offline:
Recognitions:
Re: Aleph^aleph
What doesn't? I don't understand.
Old Jul5-09, 11:34 AM                  #8
Preno
Preno is Offline:
Re: Aleph^aleph
The axiom of regularity says that you cannot have an infinite descending chain of elements, i.e. a sequence of sets LaTeX Code: x_i such that LaTeX Code: x_{i+1} \\in x_i . So you cannot "continue ad infinitum".
Old Jul5-09, 03:27 PM                  #9
Dragonfall
Dragonfall's Avatar
Dragonfall is Offline:
Recognitions:
Re: Aleph^aleph
If we're talking about ZFC.
Old Jul5-09, 07:41 PM                  #10
Phrak
Phrak is Offline:
Recognitions:
Re: Aleph^aleph
Thanks for bringing this up. What is the reason this is contained in ZFC?
Old Jul6-09, 12:04 AM                  #11
Phrak
Phrak is Offline:
Recognitions:
Re: Aleph^aleph
The idea is like taking a thing, dividing it into N pieces, dividing the pieces into N pieces, and so on, without end. Does ZFC set theory really preclude this?
Old Jul6-09, 07:34 AM                  #12
Preno
Preno is Offline:
Re: Aleph^aleph
Yes. The motivation for the ZF axioms is the "iterative concept of set", wherein you build sets from the bottom up by iterating the power set and union, in stages, starting with the empty set. In ZF, it is equivalent to transfinite epsilon induction, i.e. it gives you a mechanism for proving stuff about all sets if you know that "all elements of x have P" implies "x has P" (notice the initial step takes care of itself automatically).
For an explanation of the iterative concept of set, see for example Parsons' What Is The Iterative Conception of Set? and Boolos' The iterative conception of set.
There are also "non-well-founded" set theories which violate the axiom of regularity/foundation. IIRC they are supposed have some use in computer science. Peter Aczel studied those, see his Non-well-founded Sets (which should be available online).
Old Jul6-09, 01:38 PM       Last edited by Dragonfall; Jul6-09 at 01:44 PM..            #13
Dragonfall
Dragonfall's Avatar
Recognitions:
Re: Aleph^aleph
Pretty much the only use for the foundation axiom in ZFC is to prove that set membership is well founded, and iirc, if large cardinals exist, that V=L, Godel's constructible universe.
The main problem with non-well-founded sets is to define a notion of "equality". That and relative consistency results. To accomplish the former Aczel uses a notion borrowed from computer science, that of "bisimulation".
But even if you go with non-well-founded sets, there are no infinite descending membership chains longer than LaTeX Code: \\omega .
WRT your first post, I think what you're asking is that if you have a set of sets, what is the size of its LaTeX Code: \\in -closure?
Old Jul12-09, 11:37 AM                  #14
Phrak
Phrak is Offline:
Recognitions:
Re: Aleph^aleph
I found this statement in wikipedia,
"However, no axiom system in first order logic [such as ZFC] is strong enough to fully (categorically) describe infinite structures such as the natural numbers or the real line. Categorical axiom systems for these structures can be obtained in stronger logics such as second-order logic,"
under first order logic.
Is it true? If so, I don't think ZFC applies to sets having size of |R|, or aleph_0 for that matter.
Old Jul13-09, 10:34 AM                  #15
Dragonfall
Dragonfall's Avatar
Recognitions:
Re: Aleph^aleph
I think the keyword here is "fully (categorically)". I'm not sure what that means.
Old Jul13-09, 05:07 PM                  #16
Hurkyl
PF Mentor
Hurkyl's Avatar
Hurkyl is Offline:
Re: Aleph^aleph
You've run into one of the subtleties that can be tricky about formal logic. The point is that you've overloaded the term "cardinality" -- you're using it to refer both to the notion of cardinality defined by whatever "ambient" mathematical system you're using, and you're using it to refer to the notion of cardinality as defined by the formalization of ZFC you're studying.
Confusing the two notions of cardinality can lead to all sorts of problems -- one of the most famous is Skolem's paradox.
I've referenced wikipedia as a starting point, but do not construe that as an endorsement of the article.
image image
Reply
Thread Tools
Similar Threads for: Aleph^aleph
Thread Thread Starter Forum Replies Last Post
aleph-one ehrenfest Calculus & Beyond 3 Jul25-08 04:43 AM
aleph null ! Doom of Doom Set Theory, Logic, Probability, Statistics 4 May1-08 04:32 PM
Intuitive way to explain |Q| = aleph zero? EnumaElish Set Theory, Logic, Probability, Statistics 5 Jan9-07 11:29 AM
aleph null problem. MathematicalPhysicist Set Theory, Logic, Probability, Statistics 2 Dec11-06 01:33 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
