New Reply
Why does hot air rise?
Share Thread
Jun26-04, 04:51 AM   #18
Yeah chroot, you were right, but you could've elaborated a bit...kinda confusing to just say that it's less dense.
Jun26-04, 08:27 AM   #19
hi.
in fact rising of air depends on the tempreture profile of the atmosphere and also the tempreture of the smoke. sometimes whene the atmosphere is in the "inversion condision" there is no rising in the air!!!
it happens alot in Los Angles. where there is a very hot blast of air in higher altitudes, that makes the inversion condision.
other condisions are :
adiabatic
subadiabatic
superadiabatic
the last one is the best for rising the polutants!!!
also see the "air polution control " references.
Jun26-04, 10:43 AM   #20
Lower density vs. higher density and higher temperature vs. lower temperature explain why the upper body of air gets heated by the lower body and the lower body gets cooled by the upper body. But this doesn't by itself explain why the material and its energy don't simply diffuse across the given common boundary between them, leading ultimately to equalization of both density and temperature. Instead, new and closed boundaries are formed and the material and energy move bodily in units (upward and downward). I suspect that this fact requires more description of the process.
Jun26-04, 10:57 AM   #21
mee
Perhaps it is not so much the hot air rising but the cold air around it sinking, its pressure pushing the warm air up?
Jun27-04, 10:01 AM   #22
Why don't the cold air molecules just fall through the space between the hot air molecules and simply make a mix?
Jun27-04, 12:20 PM   #23
Quote by quartodeciman
Because they don't feel like it? Simply, fluid dynamics doesn't work that way...why it doesn't...well...anyone?
Jun27-04, 12:38 PM   #24
Interesting discussion.
There are alot of things going on when hot air rises. If you watch the smoke from a cigarette you can see that there is an initial column where the chimney effect dominates. I would say boyancy wins out over the other forces here. Then the smoke gets to a point where it suddenly becomes very turbulent. My guess about this is that the initial flow has created a Bernoulli effect where the rising smoke represents a low pressure system by virtue of its fluid speed. It starts to entrain the colder surrounding air into the flow from all horizontal directions. If you look at this region you see the flow often exhibiting a twisting motion.
There seems to be a chaotic, non-repeating, interplay between the buoyancy and this Bernoulli effect that shreds the smoke column more and more the higher up you get from the heat source. There is actually quite a bit of mixing going on and two feet above the cigarette the twists and curls of smoke are very much more spread out than they were in the initial filament-like column.
Jun27-04, 01:23 PM   #25
Take a glass box that is partitioned into two chambers, one on top of the other. In the top chamber are oxygen molecules moving at an average speed of 1000 miles per hour. In the bottom chamber oxygen molecules are moving at an average speed of 2000 miles per hour.
Now remove the partition. What happens?
The slower moving molecules will migrate downwards, because they do not have sufficient kinetic energy to maintain their elevation. On the other hand, the faster moving molecules will migrate upwards, because those that had sufficient kinetic energy to hit the top of the partition are now free to travel farther upward now that the partition has been removed. They stay towards the top because they are launched back upwards when elastically colliding with neighboring molecules.
So hot air rises.
Jun27-04, 01:34 PM   #26
Kurious:
Because the cold air molecules have less kinetic energy and are closer together than hot air molecules, and stick more to each other using electric forces ( like van der waal's and dipole forces if water is present to any large extent).This means that cold air molecules move in bigger aggregations and so may be too big to get in the gap between hot air molecules.Also, some cold air molecules will mix with hot air molecules, but it takes a long time for significant numbers to mix.There is also the possibility that as one body of air passes another friction between them creates some static electricity which could prevent molecules at different temperatures from mixing.This is probably significant for large volumes of air such as those in the Earth's atmosphere.If a hot volume of air rotates it might expel cold air molecules
like a washing machine drum kicking out water as it spin dries clothes.
Jun27-04, 02:13 PM   #27
WATER
This disscussion seem to have died out but I just thought somone might be interested...
H2O is at it's densest at approx. 4 deg centigrade and hence (regardless of the underlying principe...) the water closest to the bottom of a lake will have this temperature all-year round, assuming that the lake is not very shallow (I.E. the lake is not a puddle). Closest to the surface (0.5 to a couple of metres, depending on water opacity, air temperature, exposure to sunlight etc...) there will be a narrow zone of temperated water where the temperature wary with the seasons (cold in the winter, hot in the summer, this is the place where we like to swim). Between the two layers, there is a layer of water that keeps a quite even temperature through out the year. In the spring and in the fall the two top layers are mixed by winds (at least in the temperate areas where I live [Sweden]) and the layers are exchanging heat as well as the water is dissolving oxygen from the air. The middle layer here acts as a thermostate, effectively preserving the temperature it was given by the top layer in the last change of season and giving it back the next time season changes.
It is my understanding that the main reason for this is the low thermal conductivity of water and the energies required to stir around the bottom of a 20-30 m deep glass of water by blowing on its surface.
It is also important to note that colder water can dissolve more oxygen and that combined whit this layered structure of sea water widely influences what lives on a certain depth at certain times of the year. This is the key to great fishermanship...
as for aeroplanes
Modern aerobatic planes have symmetrical or almost symmetrical wing profiles that generate good lift regardless of which way happen to be up at the moment. The only problem I can see with inverted flight in such aircraft is the color and state of the pilots' head after a couple of hours.... :surprise:
cheers fellows
Jun27-04, 02:55 PM   #28
Quote by JohnDubYa
John, have you ever performed this demonstration, or seen it performed? If so, how could you see what was happening?
Is there any signifigance to chosing oxygen, rather than air?
Jun27-04, 06:00 PM   #29
My question was posed as a thought experiment. I have not done the experiment.
The choice of gas is irrelevant. My bad.
Jun28-04, 01:33 AM   #30
I think it would be worth actually doing, just using air for convenience, and having smoke in one of the layers so that what happens could be seen.
I have never seen anyone do this so it would be interesting to find out exactly what does happen in the situation. It is a different situation than most where hot air rises. Usually there is a specific, local heat source: a candle, a fire.
It seems to me that if hot air rises by specific virtue of its greater kinetic energy then you should be able to take any quantity of gas, contain it, and find later that the higher energy molecules have separated out and taken up position in the upper part of the container and that the lower energy molecules will be found at the bottom. You will have found Maxwell's Entity and his name is gravity.
Jun28-04, 05:19 AM   #31
Just think about a "parcel" of air.
make the energy balance around it. The parcel wich doesn't get any turbulency in it.
It will help you!!!
Jun28-04, 08:08 AM   #32
Quote by somy
It will help you!!!
A hot air balloon.
Jun28-04, 08:29 AM   #33
The hot air molecules which are zipping around much more rapidly would knock the slower, cold air molecules out of the warm air zone before they could fall very far into it.
Any cold air molecule that beat the odds and got very far into the hot ones would soon be hit so many times it would become one of the hot ones. Any hot one that hit it would become a little cooler.
Heat travels to cold, so I think the majority of the interactions would involve cold molecules being knocked away from the faster hot zone. Kinetic energy would slowly be transferred from the higher energy molecules to the lower energy ones.
Since the flow of thermal energy is really only one way, from hot to cold, and since that is a relatively slow process compared to the buoyant force, buoyancy acts first.
Jun28-04, 08:38 AM   #34
Quote by mee
I think this is correct. It seems to be what is happening in boyancy.
Buoyancy
Address:http://theory.uwinnipeg.ca/mod_tech/node67.html
New Reply
Similar discussions for: Why does hot air rise?
Thread Forum Replies
WHY is the sun red during rise and set... General Astronomy 2
does hot air rise? Classical Physics 12
Rise and Run Introductory Physics Homework 2
