Maximum shear stress in square tubing
The maximum shear stress in square tubing occurs at the neutral axis, as confirmed by user bigislander72. The equation for calculating this stress is τ_max = 0.75(V/t)[b^3 - (b - 2*t)^3]/[b^4 - (b - 2*t)^4], where V represents the transverse shear force, b is the outside width of the square tube, and t is the wall thickness. This formula is applicable under the assumption of sharp corners, effectively ignoring the impact of rounded corners.
  • Understanding of shear stress concepts
  • Familiarity with square tubing geometry
  • Knowledge of transverse shear force calculations
  • Basic proficiency in mechanics of materials
  • Research the impact of corner radii on shear stress in square tubing
  • Explore the derivation of shear stress equations in structural engineering
  • Learn about shear force distribution in different cross-sectional shapes
  • Investigate the application of shear stress calculations in real-world engineering scenarios
Mechanical engineers, structural engineers, and students studying mechanics of materials will benefit from this discussion, particularly those focused on analyzing shear stress in square tubing applications.
bigislander72
Does anyone have the equation for this. I tried one from my textbook, and the answer I get is less than the average shear stress which is impossible. So I was curious to look at onother version, because perhaps the eq. has a typo? Also, does it occur at the neutral axis like it would in a round shaft? I thought I remebered my prof. say not, but I am out of school now; don't have those resources anymore!
bigislander72: Yes, the maximum shear stress occurs at the square tube neutral axis, and is tau_max = 0.75(V/t)[b^3 - (b - 2*t)^3]/[b^4 - (b - 2*t)^4], where V = transverse shear force on cross section, b = square tube outside width, and t = wall thickness. This formula assumes sharp corners, or ignores rounded corners, which is a close enough approximation.
