Thread Closed
What bore diameter will fit a 5.4mm motor shaft?
Share Thread Thread Tools
Jul8-09, 02:28 PM   #1
Hi gurus,
I was hoping you guys can help me with a little something:
I have just purchased a 12V DC motor with a shaft diameter of 5.4mm
(Oddly enough, the description on the ebay page says 5.5mm, but the technical drawing
attached, says that its 5.4mm).
In any case - i am looking for a gear that i can attach onto this motor. However, all the gears out there have their measurements in imperial.
My question is: What bore diameter should i be looking for to attach to my motor, that has a 5.4 - 5.5mm shaft? 3/8" seems slightly too big, and 5/16" seems a little too large.
Any suggestions?
(Sorry if this seems like a silly question)
Thanks!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Jul8-09, 02:36 PM   #2
Recognitions:
Gold Membership Gold Member
5.4 mm is less than 1/4", so both of those are too big. If you can, you might get a gear with a smaller bore diameter and ream it out a bit.
Jul8-09, 03:41 PM   #3
I am attaching a drill size index for metric, English, and number sizes.
http://bobmay.astronomy.net/misc/drillchart.htm
Apparently the 5.4 mm diameter is nearly exactly a #3 drill, and there is no equivalent to 5.5 mm diameter, but is used for a M6 x 0.5 Fine thread.
Jul8-09, 05:12 PM   #4
Just checking:
Are you suggesting that i get a gear with a bore diameter SMALLER than my 5.4mm,
and then use a number 3 drill to ream out the extra bit in the inside?
Thanks turbo and bob.
Jul8-09, 05:50 PM   #5
My SDP catalog (http://www.sdp-si.com/) lists gears with 5.5mm bore. My guess is your shaft is actually 5.5mm -- but measuring is always better than guessing!
Thread Closed
Tags
bore, diameter, gear, motor, shaft
Thread Tools
Similar Threads for: What bore diameter will fit a 5.4mm motor shaft?
Thread Forum Replies
shaft diameter, Fatigue, etc. Engineering, Comp Sci, & Technology Homework 3
change in shaft diameter Engineering, Comp Sci, & Technology Homework 3
Seals for a rotating shaft? 30k+ RPM motor? Mechanical Engineering 9
shaft diameter Engineering, Comp Sci, & Technology Homework 1
Hex head motor shaft Mechanical Engineering 6
