Measuring RPMs with a Digital Multimeter
  • Thread starter Thread starter LittleBrother
    Multimeter Rpm
This discussion focuses on measuring RPMs of a DC motor using a Digital Multimeter (DMM) that can measure frequency. The proposed method involves attaching a flywheel with a magnet to the motor shaft, which would trigger a Hall-effect sensor to relay data to the DMM. An alternative method discussed is using a flywheel with a slot and a light source paired with a photoresistor. The consensus is that the photo-sensor method may provide less noise, and the concept of an encoder is highlighted as a relevant keyword for further research.
  • Understanding of Digital Multimeters (DMM) and their frequency measurement capabilities
  • Knowledge of Hall-effect sensors and their applications
  • Familiarity with photoresistor functionality and light-based sensing
  • Basic principles of rotary encoders and their types, specifically vane encoders
  • Research the design and implementation of rotary encoders
  • Learn about Hall-effect sensor applications in motor speed measurement
  • Explore the construction and use of photoresistor-based RPM measurement systems
  • Investigate the specifications and features of various Digital Multimeters for frequency measurement
Electronics enthusiasts, hobbyists building motor control systems, and engineers interested in RPM measurement techniques for DC motors.
LittleBrother
I have a Digital Multimeter (DMM) which also measures frequency. Can this be used somehow to show RPM's of a DC motor while it is running at various stable speeds? Or is there an inexpensive device which can be used to show RPM's?
If I have to build a device, my thoughts are to mount a sort of flywheel on the shaft of the motor with a magnet attached to the flywheel. The magnet would pass by a Hall-effect sensor. Then I could feed the output from the sensor to the DMM. Would this work?
An alternative would be to use a flywheel with a slot cut into it, along with a light source aimed through the slot, and a photoresistor on the other side, then feed the output to the DMM.
Thoughts anyone?
I think your alternative idea would be the best. I've got a feeling that the photo-sensors would be much less noisy than a Hall probe.
You are making what is called an encoder (consider that a key word for a web search) A common low precision form of encoder, a vane encoder, is similar to what you describe, frequently the wheel will have multiple slots.
  • · Replies 27 ·
