Is the Matrix Representation of a Unitary Operator Always a Unitary Matrix?
  • Context: Graduate
  • Thread starter Thread starter facenian
The discussion revolves around whether the matrix representation of a unitary operator is always a unitary matrix, regardless of the basis used. Participants explore this concept in the context of quantum mechanics, specifically addressing the implications of using orthogonal versus non-orthogonal bases.
  • One participant expresses confusion about a text stating that the matrix representation of a unitary operator is unitary only if the basis is orthonormal, while they believe it should be unitary regardless of the basis.
  • Another participant requests clarification on the text being referenced.
  • A specific text is cited, which claims that the representation matrices of unitary operators are unitary if the basis is orthonormal.
  • A participant suggests testing the concept with a simple example involving the identity matrix in a 2-dimensional space, questioning whether the resulting matrix is unitary when using a non-orthonormal basis.
  • Another participant provides a mathematical argument regarding the condition for a matrix to be unitary, indicating that it holds true under the assumption of an orthonormal basis but not necessarily without that assumption.
  • A later reply acknowledges a misunderstanding regarding the matrix elements of a unitary operator, realizing that they are only correctly represented in an orthonormal basis.
Participants do not reach a consensus. There are competing views regarding the conditions under which the matrix representation of a unitary operator is considered unitary, particularly in relation to the basis used.
The discussion highlights the dependence of the unitary property of matrix representations on the choice of basis, with some participants emphasizing the necessity of orthonormality for the property to hold.
facenian
I have a very basic question. I'm confused because I've read in a text that the matrix representation of a unitary operator is a unitary matrix if the basis is orthogonal, however I believe that the matrix is unitary whatever basis one uses. I'd appretiate any comments on this.
which text?
malawi_glenn said:
which text?
Quantum Mechanics(third edition) E. Merzbacher-Chapter 17 Page 418,I quote :"Since the operators U_a were assumed to be unitary, the representation matrices are also unitary if the basis is orthonormal"
Try a simple example. Take the identity matrix on a 2-dimensional space, which is clearly unitary. Use linearity to compute the matrix elements with respect to the basis [itex]e_{1}' = e_1[/itex] and [itex]e_{2}' = e_1 + e_2[/itex], where [itex]e_1[/itex] and [itex]e_1[/itex] make up an orthonormal basis.
Does this give a unitary matrix?
A unitary matrix U satisfies [itex]\sum_j U^*_{ji}U_{jk}=\delta_{ik}[/itex]. Is this satisfied by the matrix representation of a unitary operator?
[tex]\sum_j U^*_{ji}U_{jk}=\sum_j\langle j|U|i\rangle^*\langle j|U|k\rangle=\sum_j\langle i|U^\dagger|j\rangle\langle j|U|k\rangle=\langle i|U^\dagger\Big(\sum_j|j\rangle\langle j|\Big)U|k\rangle[/tex]
This reduces to [itex]\delta_{ij}[/itex] if the parenthesis is the identity operator. I can prove that it is, if I use that the basis is orthonormal, but not without that assumption. So it looks like your book is right. What makes you think it's wrong?
thank you people. The orgin of my mistake goes like this : Let T be a untiary operator and |a_i> (i=1,...n) a basis then the matrix elements satisfy,
<a_i|T|a_k>=<a_k|T^{\dag}|a_i>*=<a_k|T^{-1}|a_i>*
what a did not realize was that the matriz elementes in the basis |a_i> are <a_i|T|a_k> only if the basis is orthonomal.
Oops, I didn't realize that myself. :redface:
  • · Replies 0 ·
  • · Replies 20 ·
