How can I calculate torque and RPM for a P-51 Mustang in a Blender3d simulation?
The discussion focuses on calculating torque and RPM for a P-51 Mustang simulation in Blender3D. Key factors include the use of a constant speed, variable pitch propeller with a diameter of 11 feet 2 inches and 4 blades, which maintains RPM above half throttle. Torque is influenced by aerodynamic drag, lift, and inertia, while undercarriage drag can be calculated using surface area multiplied by mass flow. The user seeks straightforward equations to finalize their physics model.
  • Understanding of Blender3D physics engine
  • Basic principles of flight dynamics (roll, yaw, pitch)
  • Knowledge of torque calculations in aerodynamics
  • Familiarity with drag and lift concepts in aviation
  • Research torque calculations in aerodynamics
  • Learn about constant speed propeller mechanics
  • Explore Blender3D physics simulations for aircraft
  • Investigate the effects of flap adjustments on lift and drag
Aerospace enthusiasts, Blender3D users, students in physics or engineering, and anyone interested in flight simulation development.
eaglestrike
Hello people. I've been making a sim of a P-51 Mustang in Blender3d and am working on the physics. I've got the Drag, Lift and Thrust with help from here. I need help now with:
  1. Flight Dynamics (Roll, Yaw and Pitch physics)
    I need to know the amount of force regarding torque on the aircraft.
  2. A Calulation for RPM, right now I've just got it set on the 'throttle' value, meaning that it changes every time the throttle goes down. I know that RPM depends on a lot of factors, and if a calculation is available it would be great.
  3. Undercarriage Drag
    Simple. Just surface area * mass flow? and maybe rolling friction.
  4. Flap Drag and Lift
    I know that flaps alter wing area, making this pretty simple.
Not too much detail is needed (I'm a tenth grader so take it easy- not dumb either so if you explain it to me I will eventually get it :)). This is all I need to finish my physics model so please find some time to help me out (There's some really qualified people out there who might want to inspire a 14-year old!:))
Science news on Phys.org
I thought this was covered here:
https://www.physicsforums.com/showthread.php?t=302688
rpm
From post #9 in the previous thread regarding the P51: the propeller is a constant speed (variable pitch) propeller, 11 feet 2 inches in diameter with 4 blades.. The RPM will not vary much once above some minimum throttle setting, such as 1/2 throttle.
AS I can see from WWII flight tables, the RPM has a few settings, making my job easier. As you said, torque is created by aerodynamic drag and lift, plus small inertia. Are there any calculations for this? The Aileron weight can be estimated and the area is simple. As for undercarriage drag, I guess the drag is just surface area x Mass flow, plus rolling drag. Flaps just change the wing area, so some trig would work. So basically all I need is a simple equation with no complications. And blender 3d HAS a physics engine, so the rest is taken care of.
  • · Replies 30 ·
17K
  • · Replies 42 ·
11K
