Calculating Pressure of an Ideal Gas Using the PV=nRT Equation
  • Thread starter Thread starter tag16
The discussion revolves around calculating the pressure of an ideal gas using the ideal gas law equation PV=nRT. The original poster presents a scenario involving changes in volume and temperature of the gas.
  • Participants discuss the application of the ideal gas law and the necessity of using absolute temperatures. There are attempts to rearrange the equation to find the new pressure after changes in volume and temperature.
Some participants have provided guidance on the correct use of the ideal gas law and emphasized the importance of absolute temperature. There is an ongoing exploration of how to apply the formula correctly, with multiple interpretations being considered.
Participants note the significance of unit conversions and the implications of using different values for the gas constant R. There is also mention of the need to clarify the context of temperature measurements in relation to the problem.
tag16
An ideal gas that occupies 1.8 m3 at a pressure of 1.0 multiplied by 105 Pa and a temperature of 27°C is compressed to a volume of 0.80 m3 and heated to a temperature of 227°C. What is the new pressure?
PV=nRT
Not really sure what to do for this one, not really even sure this is the formula I'd want to use
That's the correct formula, except that 'nR' is constant so it simply becomes
PV/T (before) = PV/T (after)
Note that you need to use absolute (kelvin) temperatures
so would it be (1.80)(1.0x10^5)/27=P(0.80)/227?
Except you need absolute temperatures
PV=nRT
This problem seems to involve a simple IDEAL GAS. Remember, Ideal gases involves molecules of gas as POINT particles that do not involve electric forces nor volumes that molecules can fill. Using the PV = nRT seems like the correct choice. DO NOT FORGET that units are key for these first steps into studying ThermoDynamics. R = 8.314 Joules / (Mole x Kelvin) this R value is in SI units. I usually convert everything to SI units before moving forward.
R can also = .0821 (L x Atm) / (Mole x kelvin)
You mentioned Pascal. 1 pascal = 1 Newton/Meter squared.
the atkins textbook plots Pressure, Volume, and Temperature on the X, Y, Z axis. try to plot a couple of Pressure and Temperature points. Also, try plotting Volume and Temperature points. try to think about how temperature, volume of gas, and pressure of gas are related to each other when their Kinetic Energies are relatively High like in gases.
mgb_phys is underlining something very key into picking out the right values to use in your problem solving. Don't just blindly accept the given value as the value to use to plug into your formula. Instead, try to think about how the temperature was taken because 227 degrees Celsius can refer to temperature of the environment plus the temperature of the isolated gas system. Just like Gauge pressure is different from total pressure due to the environment, absolute temperature can differ from total temperature.
so would it be (1.80)(1.0x10^5)/300=P(0.80)/500?
somehow I don't think so
It's correct.
oh yeah...I put a parenthese in the wrong place when I put in my calculator...opps. Thanks
  • · Replies 67 ·
