What size inductance for a flyback transformer?
The optimal inductance for a flyback transformer is critical for ensuring efficient operation in continuous mode. If the inductance is too high, the inductor's current will rise too slowly, leading to excessive losses due to winding resistance. Conversely, if the inductance is too low, core saturation occurs at insufficient current levels. Understanding these dynamics is essential for achieving the desired output voltage and power levels in flyback transformer applications.
  • Understanding of flyback transformer operation
  • Knowledge of continuous mode versus discontinuous mode in inductors
  • Familiarity with core saturation concepts
  • Basic principles of power electronics and switching converters
  • Research methods for calculating optimal inductance for flyback transformers
  • Learn about the effects of winding resistance on transformer efficiency
  • Study core materials and their saturation characteristics
  • Explore design considerations for buck-boost converters
Electrical engineers, power electronics designers, and anyone involved in the design and optimization of flyback transformers and switching power supplies.
bitrex
I'm looking over some equations for the output of a flyback transformer (essentially the same as for a buck-boost converter) and I notice that as long as the flyback operates in the continuous mode, the inductance doesn't enter into the equation. Of course since no inductor is ideal, there must be a way to determine the optimum primary inductance for a certain output voltage and power level. How would one go about doing this? Thanks for any advice!
Edit: I've done a little more reading and I think I have some idea - if the inductor value is too high, the current through the inductor will not rise fast enough to provide enough current for the load during the switching period and there will be excessive losses in the winding resistance, and if the inductance is too low the core will saturate at too low a current. Does that sound about right?
You didn't get a reply earlier because you answered your own question. :-)
9K
  • · Replies 16 ·
