Having lots of trouble with a few problems that are due tonight
  • Thread starter Thread starter supermenscher
The original poster is facing difficulties with several physics problems related to capacitors, electric fields, and current calculations. The subject area encompasses concepts from electrostatics and circuit theory.
  • Mixed
  • The original poster attempts to apply relevant formulas for each problem but expresses confusion over the results. Some participants suggest that arithmetic errors may be the cause of the incorrect answers, while others request to see the original calculations to identify potential mistakes.
Participants are actively engaging in troubleshooting the original poster's calculations. There is a focus on verifying the arithmetic involved in the problems, and some guidance has been offered regarding checking the work shown for accuracy.
The original poster mentions a deadline for the problems, indicating a time constraint that may affect the discussion. There is also an implication that the poster is using standard physics formulas but is struggling with the application of these formulas in practice.
supermenscher
having lots of trouble with a few problems that are due tonight...please help!
1. A 0.28F capacitor is desired. What area must the plates have if they are to be separated by 1.2mm air gap?
I used C=E0 (A/d) and I keep getting the same and wrong answer. What am I doing wrong?
2. What potential difference acting over a distance of 3.5cm would be needed to balance the downward force of gravity so that an electron would remain stationary? Assume the electric field is uniform.
I used V=mass of electron*gravity*0.035m/1.6*E-19, and that gave me the wrong answer. Help anyone.
3. A 9.4V battery is connected to a bulb whose resistance is 2.1ohms. How many electrons leave the battery per minute.
I used ohm's law I=9.4/2.1 to get the current 4.476C/s. Then I multiplied 4.476c/s*60s/1.6E-19 and got 1.68E-17 electrons/minute...and that answer was wrong...any help?
Your methods all look correct. Show your work in the first two problems--I suspect an arithmetic error. That's what happened in problem 3: check those exponents.
I still keep getting the wrong answers can you show me what to do...I just plugged the numbers into the formulas
check your arithmetic
You know what to do, you are just making arithmetic errors. Show the actual numbers you are plugging into the equations.
For example, you showed your work for problem 3: The numbers are right, but the answer is wrong. Redo your calculation carefully. You messed up the exponent in the answer.
