Relative Humidity: Ice Block's Effects on Room Air | Homework Questions
The discussion revolves around the effects of a small block of ice on the air above it in a room with a temperature of 30 degrees and a relative humidity of 80%. Participants are analyzing statements regarding the absolute and relative humidity in the vicinity of the ice block compared to the surrounding air.
  • Participants explore the relationship between temperature and humidity, questioning how the presence of ice affects both absolute and relative humidity. There is uncertainty about the truth of the statements regarding humidity levels above the ice block versus the surrounding air.
Some participants have provided insights and references to external resources, suggesting that as temperature decreases, absolute humidity may also decrease. There is ongoing debate about the validity of the statements presented, with multiple interpretations being explored.
Participants are working within the constraints of the problem statement and are considering the implications of temperature changes on humidity without reaching a definitive conclusion.
leena19
Consider the folowing statements made about the space just above a small block of ice placed in still air,where the room temperature and the relative humidity are 30 degrees and80%
(A) Absolute humidity of air in the space just above the iceblock is higher than the absolute humidity of air away from the block
(B) Relative humidity of air in the space just above the ice block is higher than the Relative humidity of air away from the block.
(C) Air in the space just above the ice block is drier than the air away from the block
which of the above statements is true
(1) only A (2)A & B only (3)B &C only (4)A&Conly (5)A,B&C only
I know that Relative humidity increases when the temperature decreases,
as for absolute humidity ,I don't think the temperature has any effect on AH?but I'm not sure.
I also think the temperature above the iceblock is less than its surrounding temp. so I think B would be true and maybe A?
If B were true ,I don't think C would be true,so I think the answer is(2),but I'm very very doubtful.
Hope someone could help.
Thank you
Thanks so much for the link,sir.
so when temperature decreases,the absolute humidity decreases(dew point also decreases),
then,
(A) would be wrong,cause the temperature above the ice block would be less than the surrounding temperature,so AH would be less here than that of the surrounding,and C would be correct for the same reasons.
(B)would also be correct,
so the answer is (3) B &C only?
THANK YOU
then,
THANK YOU
I'd think so. Remember Absolute Humidity is the amount of water that a volume of air holds. The relative humidity is what percentage of the 100% absolute humidity is measured at a particular temperature.
Absolute humidity is mass/volume and relative humidity is a %.
http://en.wikipedia.org/wiki/Absolute_humidity#Absolute_humidity
  • · Replies 19 ·
