Signals and Systems, system properties
The discussion centers on the stability of the systems defined by the equations y(t) = t x(t) and y(t) = x(t)/t. It is established that y(t) = t x(t) can be considered stable under certain conditions where x(t) does not approach infinity. However, as t approaches zero, both systems yield unbounded outputs from bounded inputs, confirming their instability. The consensus is that y(t) = x(t)/t is inherently unstable due to its behavior at t equal to zero.
  • Understanding of system stability in control theory
  • Familiarity with bounded and unbounded outputs
  • Knowledge of the behavior of functions as they approach limits
  • Basic concepts of signals and systems analysis
  • Study the concept of stability in linear time-invariant (LTI) systems
  • Learn about the implications of bounded inputs and outputs in control systems
  • Explore the mathematical analysis of limits in signal processing
  • Investigate the properties of continuous-time systems and their stability criteria
Students and professionals in electrical engineering, control systems engineers, and anyone studying signals and systems who seeks to understand system stability and behavior under various conditions.
freydawg56
I know that y(t) = t x(t) is unstable, for bounded inputs yielding unbounded outputs, but would
y(t) = x(t)/ t also be unstable? when t is going in the negative direction? please help. test Monday.
As t approaches zero, you get unbounded outputs from bounded inputs. So, it is unstable.
Also, please somebody correct me if I am wrong, but I believe y(t) = t x(t) does in fact have a bounded output for a bounded input. If you don't let x go to infinity, then y will also not go to infinity, and is therefore bounded and stable.
No, even with a bounded x, y will grow with time, so it is unbounded.
As, for the original question, x(t)/t is unstable for t equal zero, so no real system can have such characteristics.
