Magnetostrictive properties of steel
  • Thread starter Thread starter dondante
    Properties Steel
The discussion focuses on the magnetostrictive properties of bright mild steel, specifically C1018 with a carbon content of 0.15. The user seeks data on the elongation versus magnetic field strength curve for this material, which is critical for their engineering thesis involving pulse-echo thermometry. The application involves sending a pulse through a 2m steel rod and capturing the echoed pulse with a coil. Historical context is provided regarding the use of thin magnetostrictive wires in high energy physics applications.
  • Understanding of magnetostrictive materials and their properties
  • Familiarity with pulse-echo thermometry techniques
  • Knowledge of coil design and operation in electromagnetic applications
  • Basic principles of high energy physics and position resolution measurement
  • Research the elongation vs magnetic field strength characteristics of C1018 steel
  • Explore advanced pulse-echo thermometry methods and applications
  • Investigate the design and implementation of magnetostrictive sensors
  • Study the historical applications of magnetostrictive materials in physics experiments
Engineers, materials scientists, and researchers involved in magnetostrictive applications, particularly those working with steel and pulse-echo techniques in experimental physics.
dondante
Hi,
I'm looking for the magnetostrictive properties of bright mild steel (C = 0.15). I'm especially interested in its elongation vs magnetic field strength curve. I've been looking everywhere and can't seem to find any data.
Currently I'm busy with my engineering thesis on pulse-echo thermometry. I'm planning to send a pulse down a 2m steel rod (C1018) using a coil. The echoed pulse is picked up with a different coil.
I hope someone can help.
Cheers.
We used to use thin magnetostrictive wires (< 1/16" dia) to read out high energy physics spark chambers with roughly 1 mm position resolution using the time delay of the magnetostriction pulse. See
http://adsabs.harvard.edu/abs/1966ihep.conf...29P
(This is a pay per view paper)
10K
11K
