Transmitting portion of a transmitter works
  • Context: Undergrad
  • Thread starter Thread starter Aethaeon
    Transmitter Works
The discussion centers on the functioning of the transmitting portion of a transmitter, particularly focusing on how to efficiently generate electromagnetic (EM) waves and the role of antennas in this process. Participants explore theoretical and practical aspects of signal transmission, modulation, and antenna behavior.
  • One participant expresses confusion about how to generate EM waves from an already amplified signal and seeks clarification on antenna operation.
  • Another participant explains that EM waves are generated using crystal oscillators or variable frequency oscillators (VFOs), which are then amplified and matched to the antenna's impedance.
  • A participant questions the oscillation of electrons in an antenna, noting that it seems like an open circuit and asks why electrons would oscillate.
  • In response, it is explained that at radio frequencies, the antenna is not an open circuit, and the oscillation of electrons occurs due to the excitation by RF signals, with the antenna length being critical for efficient radiation.
  • One participant challenges the idea of using a hacked power cord to generate EM waves at 60 Hz, stating that the required length for effective radiation would be impractically long.
Participants do not reach a consensus on the mechanics of antenna operation, with ongoing questions about electron oscillation and practical applications of power cords for EM wave generation. Multiple competing views and uncertainties remain present in the discussion.
The discussion includes assumptions about antenna behavior at different frequencies and the implications of antenna length on radiation efficiency, which are not fully resolved. There are also unresolved questions regarding the practical application of theoretical concepts in real-world scenarios.
Aethaeon
(Update -- please read the third post -- I guess I'm wondering how an antenna works in particular).Hey,
I can't seem to find much information on how the actually transmitting portion of a transmitter works -- how does one efficiently generate EM waves?
Thanks!(I'm aware that the rough idea is to accelerate charges back and forth at a particular frequency, what I want to know is how one actually goes about doing that)
Welcome to PF. Briefly, EM waves in the radio frequency band are generated using crystal oscillators or VFOs. The signal is then amplified to the desired power level and fed to the antenna through a matching network which matches the impedance of the amplifier to the impedance of the transmission line. Modulation of the signal depends on the mode (AM, FM, SSB etc...) You may find one or more of these books of interest:
http://www.arrl.org/catalog/index.php3?category=Help+for+Beginners
Thanks for the reply, TurtleMeister.
I should clarify exactly what I was wondering --
Suppose I already have a signal that I want to transmit, and its already amplified, etc. How do I actually turn that signal into EM waves?
I guess, basically, I don't understand how to analyze how an antenna works. Since an antenna is conductive, so there's no potential across any parts of it -- why do electrons in the antenna oscillate?
If I hack apart a power cord to get a plug and two bare wires, I ground one and leave the other one free, and then plug it in, will I get strong EM waves at 60 Hz (outlet frequency)?
The electrons oscillate in an antenna for the same reason they oscillate in an electric light bulb. They are forced to do so by the power source. However, that is where the similarity ends. The difference is in the frequency of oscillation.
The antenna may seem like an open circuit but it's not at rf frequencies. The reason has to do with the frequency and the length of the antenna. When a dipole antenna is excited with RF, electrons will flow back and forth at nearly the speed of light. When the antenna length matches the wavelength of the RF then the antenna will radiate with maximum efficiency. The length of the dipole can be determined by: l = 468,000,000 / f where l is the antenna length in feet and f is the frequency in hertz. The antenna is not an open circuit because the electrons never have time to travel farther than the wavelength of the frequency.
No. If you use the formula you will see that your power cord would need to be 7,800,000 feet long.
Edit: Actually, since you're grounding one side of the power cord it would be 3,900,000 feet for a quarter wave.
As a means of monitoring activity in a number of manufacturing facilities, marine research, and general production control, a pressure transmitter will not only help to ensure positive results; it also can be a great way of maintaining acceptable levels of safety.
1. a. An electronic device that generates and amplifies a carrier wave, modulates it with a meaningful signal derived from speech or other sources, and radiates the resulting signal from an antenna. b. The portion of a telephone that converts the incident sounds into electrical impulses that are conveyed to a remote receiver. c. A telegraphic sending instrument. 2. A neurotransmitter.
  • · Replies 31 ·
  • · Replies 49 ·
