Can Two Sets Be Checked for Equality in Less Than O(nlogn) Time?
  • Thread starter Thread starter daniel_i_l
    Element
Determining if a number appears only once in an unsorted array of integers can be achieved in linear time, O(n), using a hash map. The discussion highlights that while sorting the array takes O(n log n) time, an efficient algorithm utilizes a two-bit field array to track occurrences, requiring 4GB of memory for 32-bit integers. An alternative method involves incrementing and decrementing a counter for first and second occurrences, which also operates in O(n) time. Overall, while O(n log n) is feasible, O(n) is optimal for this problem.
  • Understanding of hash maps and their time complexity
  • Familiarity with bit manipulation and memory allocation
  • Knowledge of time complexity analysis
  • Basic programming skills in Python or C
  • Implement the O(n) algorithm using a hash map in Python
  • Explore bit manipulation techniques for tracking occurrences
  • Study time complexity implications of different data structures
  • Learn about memory management in C for optimizing performance
Software developers, algorithm enthusiasts, and computer science students interested in optimizing search algorithms and understanding time complexity in data structures.
daniel_i_l
Let's say I have an unsorted array of integers. Is it possible to determine if there exists a number in the array that appears only once with a time complexity of less than O(nlogn)? Sorting the array takes nlogn time so I'm wondering if it's possible without sorting. I don't need to return the element, only to determine that it exists.
I think that the answer is no. If it was possible than it'd also be possible to check if two sets are equal or not in less that nlogn time since you could simply connect the sets and check if there's a unique element. Does anyone know the best algorithm for checking if two sets are equal?
Thanks,
Daniel
Technology news on Phys.org
Depends on the range of integer values versus the size of the available memory. For 32 bit integers, you'd need 4GB of 2 bit fields which would require 1GB of memory, something that would be available on most PC's these days.
You'd start off with a zeroed out array of 2 bit fields. You'd then make a single pass over the array of integers, using the integer value as an index into the array of 2 bit fields. If it's the first occurrence, the bit field value will be 0 and you change it to 1. If it's not the first occurrence, then the bit field value will be non-zero and you change it to an 2 (if it's already 2, you don't need to change it).
After you're done, you make a single pass on the array of bit fields, and output the index of every instance where the value is 1.
update This process would take n + 4GB steps. If n is relatively small, then it would be better to use a n(log(n)) type algorithm. Sorting in ram is fairly fast.
If you don't need to know the values of the unique number(s) in the array, then you can just use a counter that is incremented every time you find a "first occurrence" and decremented every time you find a "second" occurrence, and not modified if you find a 3rd or more occurrence (2 bit field already set to 2). This process would only take n steps.
This might be faster than sorting:
Code:
def hasuniq(list):
  hashmap = {}
  unmatched = 0
  for x in list:
    if x in hashmap:
      if hashmap[x] == True:
        unmatched -= 1
        hashmap[x] = False
    else:
      unmatched += 1
      hashmap[x] = True
  return unmatched > 0
The precise time complexity of this depends on the size of your hashtable and assumes that the values don't hash pathologically, but if you wrote it in C it could probably be made faster for most cases than the equivalent sort in C.
Really though, n log n (by sorting) is going to be fast enough. log n is almost a constant time factor difference, for practical input sizes.
  • · Replies 20 ·
  • · Replies 31 ·
14K
