Calculating Randomly Truncated PDF for X given T1 < X < T2
  • Context: Graduate
  • Thread starter Thread starter benjaminmar8
    Pdf Truncated
The discussion revolves around calculating the probability density function (pdf) of a random variable X given that it is truncated by two other random variables T1 and T2, specifically under the condition T1 < X < T2. Participants explore the theoretical framework, mathematical formulations, and potential challenges in deriving the truncated pdf.
  • One participant presents a mathematical expression for the conditional pdf f(x|t1
  • Another participant questions how to determine when T1 < X < T2 since T1 and T2 are random variables, suggesting that all possibilities for T1 and T2 should be considered.
  • A participant mentions that simulations indicate the need for scaling the pdf f(x|t1
  • One participant clarifies that the previously provided expression does not represent the conventional conditional probability and distinguishes it from a randomly truncated pdf, expressing uncertainty about the specific problem being addressed.
  • Another participant suggests using the cumulative distribution function (CDF) and differentiation to derive the conditional pdf, indicating that both probabilities involved can be expressed as integrals of the pdfs.
Participants express differing views on the correct formulation of the truncated pdf and the implications of treating T1 and T2 as random variables. There is no consensus on the exact method to compute the pdf or the necessary conditions for scaling.
Participants note potential limitations in their approaches, including assumptions about the support of the random variables and the need for approximations in scaling the pdf. The discussion highlights unresolved mathematical steps and the complexity of integrating over random variables.
benjaminmar8
Hi, all,
I am having a problem in calculating a randomly truncated pdf. Let x be a random variable, it's pdf f(x) is known. Let t1 and t2 be anther two random variables, their pdf f(t1) and f(t2) are known as well. Now, how do I compute the pdf f(x|t1<x<t2)?
Thks a lot.
[tex]f(x|t_1<x<t_2)=\int_{-\infty}^{-\infty}\int_{-\infty}^{-\infty}f(x)rect(x,t_1,t_2)f(t_1)f(t_2)dt_1dt_2[/tex]
where [tex]rect(x,t_1,t_2)[/tex] is defined to be [tex]1[/tex] if [tex]t_1<x<t_2[/tex] and [tex]0[/tex] otherwise.
But the question is, how do I know when t1<X<t2 since t1 and t2 are random?
You don't. You consider all possibles for t1, and t2 and the probability of each possibility.
I did a couple of simulations and found that the pdf f(x|t1<x<t2) seems need to be scaled. Maybe I have miss out some conditions, say the support of x, t1 and t2 are all [0,R]. In this case, how do I compute the truncated pdf? Thanks a lot.
I'm sorry. What I gave you wasn't really f(x|t1<x<t2). To get the conventional probability, simply divide f(x) by the integral of f(x) from t1 to t2. However, the contional probability is not the same thing as a randomly truncated PDF. What I gave you is the distribution of f(x) given some random truncation. I'm not sure which you want because I don't know much about the problem you are trying to solve.
what I am trying to solve is the desnity function of f(x|t1<x<t2), therefore, its intergral over the support should be 1. What you gave me seems should be devided by 1/(F(t2)-F(t1)) (and you mentioned that), however, since t2 and t1 are random, I use its expectation instead. That's to say, the scaling is 1/(F(E[t2])-F(E[t1])). I know this is an approximation, how do I compute it in an exact manner? Thank u very much.
I'd start with the CDF and differentiate.
F[x|t1<x<t2] = P[t1<X<t2 & X<=x] / P[t1<X<t2]
both those probabilities can be written as integrals of functions of the pdf's.
