Lagrange Multipliers - unknown values
The discussion focuses on solving a problem using Lagrange Multipliers to find the maximum and minimum values of the function f(x,y,z) = x^2 - 2y + 2z^2 under the constraint x^2 + y^2 + z^2 = 1. The participants clarify the steps to derive the values of x, y, and z, particularly how to handle the case where λ (lambda) equals 2, leading to y = -1/2 and z = ±√(3)/2. The solution involves equating gradients and applying the constraint effectively to find all critical points.
  • Understanding of Lagrange Multipliers
  • Familiarity with gradient vectors
  • Knowledge of multivariable calculus
  • Ability to solve quadratic equations
  • Study the application of Lagrange Multipliers in optimization problems
  • Learn how to compute gradients for multivariable functions
  • Explore constraints in optimization and their implications
  • Practice solving similar problems involving Lagrange Multipliers
Students and educators in calculus, mathematicians focusing on optimization techniques, and anyone looking to deepen their understanding of Lagrange Multipliers in multivariable calculus.
maks4
Using Lagrange Multipliers, we are to find the maximum and minimum values of f(x,y) subject to the given constraint
f(x,y,z) = x^2 - 2y + 2z^2, constraint: x^2 + y^2 + z^2 = 1
grad f = lambda*grad g
(2x, -2, 4z) = lambda(2x, 2y, 2z)
therefore: 2x = lambda2x
-2 = lambda2y
4z = lambda2z
Now i can see how x and z can both equal 0, and how lambda can equal 1, and how y eventually equals -1 and f(0,-1,0)=2, yet in the solutions there is another part to it where it says
OR, Lambda = 2, y = -1/2, x = 0, z= +- sqrt(3)/2. <---i do not have any idea how these values came to be, no idea at all. Any help would be appreciated, thanks.
If
[tex]4z = 2z \lambda[/tex] then you get that either z=0, or if z is non-zero, it must be lambda=2. Then you just work from there - y comes easily next, followed up by x, and then using the constraint to solve for what z actually is
^^I see it now then, thank you.
  • · Replies 16 ·
  • · Replies 18 ·
