Experimenting: Finding Out What Affects Wood Block Tip Height
  • Context: High School
  • Thread starter Thread starter SkyeLilly
    Block Height Wood
The discussion revolves around an experiment aimed at determining the factors that influence the height at which a block of wood tips when pushed. Participants explore methods for applying a consistent force to the block during the experiment.
  • Experimental/applied
  • One participant seeks ideas for applying a consistent force to a wood block in an experiment.
  • Another participant suggests using spring or magnetically loaded mechanisms to achieve a consistent push force, or alternatively, dropping the block from a controlled height to utilize gravitational acceleration.
  • A different participant mentions that rubber bands can be effective for providing a consistent force in such experiments.
  • Another idea proposed involves using a simple pendulum with a fixed initial angular displacement, noting that the height of the pivot point could be adjusted or the block could be placed on surfaces of varying heights, while maintaining a consistent friction coefficient.
Participants present multiple approaches for applying a consistent force, indicating a variety of methods that could be used, but there is no consensus on a single best method.
Considerations include the need for consistent friction coefficients across different surfaces and the potential impact of varying pivot heights in the pendulum approach.
This discussion may be useful for individuals interested in experimental physics, particularly those exploring mechanics and forces in practical applications.
SkyeLilly
I am doing an experiment.
For this experiment I am going to find out what has more effect on the height a block of wood will tip when pushed.
I need some ideas on how to push the block of wood with the same force each time?
any thing spring or magnetically loaded can produce a consistent push force. Or if you want to go really low tech there's always simply dropping it from a controlled appartus. That 9.8m/s^2 is pretty stable.
I always find for these sort of things rubber bands are useful
A simple pendulum with fixed initial angular displacement and a pivot point of adjustable height could do the trick.
P.S. The adjustable height of the pivot point could be neglected if the standing block is placed on surfaces of increasing height. Ideally, the friction coefficient should be the same for each surface.
  • · Replies 16 ·
  • · Replies 27 ·
  • · Replies 28 ·
