Where Can I Find Detailed Plans for Building a Real Railgun?
  • Thread starter Thread starter arumz
    Research
The discussion centers around the feasibility and planning of constructing a railgun as part of a high school research project. Participants explore various aspects of railgun technology, including construction plans, theoretical underpinnings, and practical challenges involved in building such a device.
  • Homework-related
  • One participant seeks detailed construction plans for a railgun, emphasizing the desire to build a real but not overly powerful version.
  • Another participant questions the research value of simply building from existing plans and suggests that finding detailed plans may be unlikely due to the complexity of railgun technology.
  • Concerns are raised about the affordability and complexity of the necessary components for constructing a functional railgun.
  • A proposed approach involves using a steel tube for the rails and a metal block as a projectile, with a car battery for power, aiming for a proof of concept rather than a fully functional model.
  • One participant expresses interest in examining the correlation between voltage and recoil, stating that they have access to necessary equipment and funding.
  • Another participant offers a theoretical perspective on recoil, suggesting that it can be predicted analytically and that plotting voltage versus recoil may not effectively describe railgun performance.
  • There is a suggestion that using quickly varying AC current rather than static DC current is crucial for understanding the forces involved in railgun operation.
  • A later reply proposes that building a coilgun might be a more suitable and "cooler" project for a high school setting.
Participants express differing views on the feasibility of building a railgun, with some emphasizing the challenges and complexity involved, while others maintain that it is possible with the right resources. There is no consensus on the best approach or the validity of the proposed methods.
Participants highlight various assumptions regarding the availability of materials, the complexity of construction, and the theoretical aspects of railgun operation. There are unresolved questions about the necessary equipment and the effectiveness of proposed methods for measuring performance.
arumz
As a Senior in high school I am conducting a research project. I have spent numerous hours searching the web and becoming familiar with railguns. Now I need to start constructing but I need a good, detailed set of plans to start with. I am not looking to build a massive one or even very powerful but a real railgun.
Where can I find or get construction plans for a railgun??
I really need some help. Anything is appreciated.
Well first of all before you start anything, what is the aim of the project?
As simply building a railgun from someones existing plans, is not in any way research, also I doubt that you can find a set of construction plans anywhere. These things arent mechano, they are a new piece of technology.
Also are you thinking of railguns or coilguns?
I seriously doubt you will be able to afford the parts or technology required to make a railgun work. The complexity required just to make a "simple" one would be quite daunting. You definitely won't be able to find detailed plans for one you can build in your garage.
In theory the mechanical part of these devices aren't very complex. I would think the electrical part would be the most complex and dangerous. If I were doing a project such as this, I would take a steel tube and cut it lengthwise such that I had my two "rails". My projectile would be a metal block with circular cuts milled to the sides. I would then use ball bearings between the projectile and the rails.
I would then use a car battery with plenty of resistors and the goal would be to simply show a proof of concept that yes, I can move the projectile down the rails using only electricity. Do not use the high amps needed for practical demonstration.
For the overall research I would like to examine the recoil as the voltage increases to chart the correlation. I would definitely like to construct a rail gun and will. It is just a matter of how. I have access to all the needed equipment as far as I can tell and funding should not be an issue.
Recoil is something that you can predict analytically, and should be pretty close. From your voltage you can calculate force on the projectile and consequent acceleration. From conservation laws, you should then be able to calculate the reaction force.
The only thing you'll show by plotting recoil is that frictional losses.
Plotting the "voltage" versus recoil is a useless quantity for describing the performance of a railgun. First, the acceleration is achieved with quickly varying AC current(not a static DC current) which changes as it is applied to different magnetic coils when projectile accelerates down he barrel. Second, voltage alone is not enough to describe the force, acceleration, or power being imparted on the projectile; you would want to graph something like power or impulse which in itself could be used to calculate the projectile's acceleration (and thus the gun's recoil).
Well then let me ask- what equipment do you think is required to build and operate a small railgun? You say you have access to all of the equipment you need and price is not a problem so that tells me you already know all of the components required to build one...
You won't be able to build a railgun, just build a coil gun. It's much cooler as a high school project.
9K
27K
  • · Replies 16 ·
